Old 01-22-2017, 01:39 AM   #1
mkpont@gmail.com
Adding Vortex motor in 94 truck
Need some help!!!!!!!
I got a 94 Chevy SWB with a stock 210 HP 5.7 and want to change to a 290 HP Vortec Chevy Crate motor. What changes do I need to do to make it work?????
I want to continue to use the TBI, with using the Eldabrock Alum intake.
Will the Computer, Motor Mounts work?????
Will my 94 stock auto trans work?????
What type of exhaust mainifolds should I use??????
I talked to the Chevy Peformance Center and they said the Vortec motor will not work with my computer...
Any suggestions or comments??????
Mike
mkpont@gmail.com is offline   Reply With Quote
Old 01-22-2017, 09:26 AM   #2
b454rat
Re: Adding Vortex motor in 94 truck
You can use the long block but will need a carbed intake for the Vortec heads. Get an adapter for TBI to 4 barrel, everything else will bolt on. Trans will bolt up and work, the biggest issue is with the ECM, will need a custom tune to run properly.
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 01-22-2017, 10:55 AM   #3
Eastonspeedworks
Eastonspeedworks's Avatar
Here's a simple solution to the intake problem. https://m.summitracing.com/parts/nal...FRGewAodOwQMCQ But you need a different egr, vortec exhaust manifolds, vortec front accessory drive, different flywheel and oil pan for the one piece rear main. The lost goes on and on unless you find a good donor truck you will spend more money on misc parts than to build/buy a far superior motor with a new tune. Also you need to run a melonized distributor gear with that roller cam.
Eastonspeedworks is offline   Reply With Quote
Old 01-22-2017, 12:04 PM   #4
mkpont@gmail.com
Old 01-22-2017, 12:06 PM   #5
mkpont@gmail.com
Thank you,
I was hoping that the accessories and all the misc stuff would work from old truck.
Thanks for the info.
Makes me think.
Mike
Old 01-22-2017, 02:39 PM   #6
95 S_Trucker
95 S_Trucker's Avatar
A 94 will already have a 1 piece rear seal. Your exhaust manifolds will bolt right on. Your front accessories will bolt right on. If you use the intake manifold in post 2, you will be able to keep the egr, as long as the valve doesn't interfere with the thermostat housing. Your engine mounts, flexplate, and transmission will all swap over without a problem. You can use your distributor with the melonized gear.
It may run fine with your existing pcm, or you may need a custom chip programmed.
95 S_Trucker is offline   Reply With Quote
Old 01-22-2017, 03:20 PM   #7
mkpont@gmail.com
Thank you for the info.
Have you done this swap before?
Will the motor mounts and oil pan work?
Thanks.
Mike
Old 01-22-2017, 07:18 PM   #8
sntrym95
sntrym95's Avatar
I just did this swap on my 95 Yukon. You will need a computer chip, higher pressure TBI spring, higher volume fuel pump, and some fittings for the intake (if you use the GMPP tbi to vortec intake).
I spent most of the time on this with the engine on the stand making sure everything lined up. I did have to do some light fabrication on the throttle/cruise bracket and the MAP sensor bracket to get them to work with the new manifold. The base engine block is the same for the TBI and the Vortec, so the motor mounts bolt right up. I used a pan that comes with the Vortec since I bought the motor with heads and pan.
Mike
sntrym95 is offline   Reply With Quote
Old 01-22-2017, 09:58 PM   #9
mkpont@gmail.com
Thank you for your reply.
What exhaust manifolds did you use?
Can you feel the increase in power?
Thanks again.
Mike
Old 01-22-2017, 10:51 PM   #10
sntrym95
sntrym95's Avatar
Since I'm using EGR, I used Gibson GP102S stainless headers. If you are using EGR, you'll need manifolds or headers with the EGR provision. If you are not planning on using EGR, then you can use the manifolds from your current truck.
Mike
Old 01-22-2017, 11:10 PM   #11
sntrym95
sntrym95's Avatar
Here are my notes from the swap:
GM TBI to Vortec manifold 12486572
Driver's side exhaust manifold or headers with EGR tube. I'm going with Gibson GP102S (if you care about EGR)
EGR tube for Vortec 10242876 (Dorman 598-200) (if you care about EGR)
Chip kit from tbichips.com - pcm chip, 18psi spring (see fuel pump note below)
Intake bolts (8) - 12550027
Intake gaskets - MS901312
Dizzy with melodized cam gear - https://www.summitracing.com/oh/part...0200/overview/ - I couldn't find the gear with my shaft diameter (.0430) so I bought a new dizzy with the correct gear
3/8 npt to 1/2" nipple right angle - for brake booster. I used a 1/2" heater hose to connect from the nipple to the brake booster
Valve cover grommets (2) 3989350 - just a replacement of worn parts
Fuel pump assembly - 19153722 - I needed the entire assembly for the 4 door Yukon. You will just need a higher volume fuel pump. TBIChips.com has a kit with the pump (see note above)
2x -5/8 nipple to 1/2npt 90 degree (for coolant - you'll need to put in a bypass as the Vortec heads do not have the provision. For the manifold I used, I ran a hose from the front top hole to the heater core, the heater core to the radiator, and the rear top hole on the manifold to the water pump.
3/4" freeze plug for the timing cover where the crankshaft position sensor would go. A little rtv, tap it in gently. If you don't use the Vortec timing cover, you don't need to do this. The motor I bought was already assembled as a long block.
Some 5/8 and 1/2 hose, clamps, vacuum hose, etc.
All of the accessories bolted up no problem. The one bar support for the tensioner doesn't fit since you are using vertical bolts instead of angled. I haven't made anything for it yet, but it doesn't seem to need it.
For the MAP sensor bracket, I had to cut off about 3/8 of an inch then drill another 5/16 hole in it to mount it with the manifold to head bolt.
For the throttle cable bracket, I had to fold the bottom plate over 180 degrees and bend it a little to get it to fit where the manifold to head bolt goes. I think I had to trim it a little too. I thought about using the 96-99 throttle bracket, so I picked one up from the local boneyard, but the clip sizes are different and it wont work unless you swap the clips.
Other than that, it's not too bad. I have noticed big improvement in acceleration - mostly just smooth and quick if you're on throttle just a little. I added an AAM TracRite posi and it will spin the tires easily if you gun it. Mileage is probably not as good as it was, but it definitely pulls better than the TB I motor.
Mike
Old 01-23-2017, 08:03 AM   #12
95 S_Trucker
Thanks.
Mike
I have not done this swap before. I am very familiar with these trucks and with these engines.
You can use the oil pan and your engine mounts off your TBI motor and put them on your Vortec.
Its good that someone here has done this swap.
Old 01-23-2017, 09:17 AM   #13
Marv D
Registered Truck Offender
Marv D's Avatar
Pretty much the same encountered here but my Vortec is stroked, 383 with RHS Vortec iron heads, and I used a Holley 670cfm throttle body on that same intake as sntry, (had to bore the intake for the larger throttle blades of the Holley TB but that's no biggie) The Holley TB accepts a JET adjustable fuel pressure regulator and used the stock 94 fuel pump. Stock PSI for the 94 TB is 9-13 psi.
All of the stock accessories and everything bolted up file, except for the same bracketry issues as sntrym had .
I did a EGR delete and used JBA stainless short headers (I had a cracked stock manifold so had to do something and this seemed wiser than finding a new stock one)
Mine is a NV4500 and NP241 4x4 and had no problems with the stock hyd. clutch / bell housing flywheel etc.
Ends up looking like....
I've had big issues finding a decent tune (have around 50k miles on it now) and on the 5th chip. Pulls my 9000 pound race trailer MUCH better than the wimpy stock LO5 190HP 5.7. for sure,, but still isn't 1/10th the toter of a pig block or diesel. But empty it's a BLAST to drive.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
