Old 02-14-2017, 01:11 PM   #1
Raparham
Rear mount gas tank
i bought an A/M rear mount gas tank. Fits between the frame rails behind the axle. Should I bolt it directly to the frame?
Raparham is offline   Reply With Quote
Old 02-14-2017, 01:42 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Rear mount gas tank
I don't know what A/M is?
If it was designed to be used with straps the flange isn't strong enough to support the weight of the tank, use the straps (IE, stock style tanks).
If the flange has a bunch of holes drilled in it and didn't come with straps, *probably yes*. Pretty much all aftermarket "square" tanks I've seen seem to be frame mount.
Gas weighs a little over 6 lbs/gal, so a full tank can be over 120 lbs!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-14-2017, 02:06 PM   #3
Raparham
A/M is my abbreviation for aftermarket (lazy). Thanks for the input. I hadn't thought about the weight aspect. Problem is the straps it came with don't fit it very well. I guess I will figure a way to re-bend them so they fit the tank.
Old 02-14-2017, 02:12 PM   #4
67ChevyRedneck
That extra weight over the rear axle helps with traction and autocross events!
I couldn't get mine to fit right either, so I ran them front to back using the cross members below:
Check out my old thread here, especially post #3.
http://67-72chevytrucks.com/vboard/s...d.php?t=197895
It's been under the truck almost 11 years now. It actually worked out because I bought a hitch for the truck and it wouldn't have fit with the straps the other way.
Jesse James
Project "On a Dime"
