WTB-Pedal assembly for 85 Manual
WTB-
Planning to swap a NV4500 into my 85 K20. Looking for a pedal assembly for a clutch application. Thanks-Mike |
Junior Member
Re: WTB-Pedal assembly for 85 Manual
I've got a complete setup from an 86. Are you wanting vacuum or hydroboost for the pedal assy?
1969 impala conv 427 #s loaded. dad bought new 1969 "Judge" RA-3, rare warwick blue/white, #'s 1968 vet convertible #s 427/435 tripower (sold) 1968 belair 2door post #s 427/385 1936 ford 5w coupe dads 1st car 1969 camaro ss (17,xxx) miles Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project. |
Hydro
If you are still looking, I also have one. From an 80s truck, hydraulic clutch. I would have to check on the brakes.
Was planning to do an sm465 swap in my K5 but lost interest. Its available if you don't go with 1968vet's
1988 "Crane Truck" C30 - 350, SM465, with a 15' knuckle crane - thread 1986 M1009 - 6.2 Diesel, SM465, 2 speed aux trans, NP205 - thread 1979 Corvette - 350 T5 1977 Jimmy - 350, TH400, NP203 1982 Blazer - 350, 700R4, NP208 - Totalled, now a parts truck ![]() Scratch built 16' flatbed trailer - thread |
Junior Member
Sorry, I don't have a hydroboost at the moment. I just sold 2 vacuum this week. I thought I had one of each.
Are you saying there is a difference between a hydro-boost versus a vacuum? Are they the same for 73-87, other than that?
hey 79 vette,
Thanks. I'm still researching and looking for one. I'm not getting why the brake brackets would be different. I find several vacuum to hydro conversions online and they don't contain anything as far as the mounting bracket goes? |
![]() Join Date: Jun 2009
The brake pedal is different for hydro boost trucks. Also the main bracket that holds both pedals is different. Hydroboost trucks only have 2 studs that go through the firewall. Vacuum boost trucks have 4. Either bracket can be modified to fit what braking system you have with minor effort but the ideal situation is to have the correct one for your truck
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
Mine definitely has 4 studs that go through the firewall, and I was planning to put it in a vacuum brake truck. I had no idea the pedal boxes were different.
Based on the 4 studs, I gather that makes it for vacuum brakes? Also, it came from a hydraulic-clutch truck. IDK if there are differences between mechanical and hydraulic clutch pedals. Maybe someone else can help on that?
Junior Member
I believe -1774btcrew- just answered your question. There is a difference in the clutch pedal assemblies from hydro and vacuum (brake pedal pin location) and explained it about as good as it gets. If you search the topic you will see he knows his stuff! Heard nightmares about people trying to swap pedals from either or and not using the correct ones.
Good luck!
Thanks everyone. 1774btcrew- if you can locate one, I'm ready to buy. I see your in Az too. Thanks, Mike
So-I believe from the advice above, this is what I'm in need of:
If anyone comes across one, please let me know. Thanks |
#13 |
Sorry I haven't replied to your PM. I have been out of town. I currently only have to vacuum boost hydraulic pedal assemblies in stock. Where in AZ are you located?
#14 |
Thanks. Sending you a PM.
#15 |
hey 1774btcrew,
Can the pedal assembly from a mechanical clutch be used (or easily modified) for use with the hydro-clutch setup? I found a hydroboost one like I need but now I'm wondering about the clutch part. Thanks, Mike |
#16 |
It can be modified but not easily. I feel a big important part of the hydraulic clutch pedal assembly is the rods that come off the clutch pedal that support the clutch master cylinder. I guess if you were a really good fabricator, you could make them but I think time wise it wouldn't make sense for what you can buy a pedal assembly for. Mine are some of the most if not most expensive on eBay. This is due to the fact that I completely remanufacture them to better than new standards. Welding on the pin for the clutch master cylinder is almost always necessary unless you get one from a super low mileage vehicle. The pin gets worn and doesn't push the rod on the clutch master cylinder as far thus making it harder to engage the clutch. Most sellers don't repair this area. If you can weld and are patient this can be repaired relatively easily.
#17 |
Thanks 1774btcrew, can you put me in line for the next one you have available?
Mike QUOTE=1774btcrew;7878103]It can be modified but not easily. I feel a big important part of the hydraulic clutch pedal assembly is the rods that come off the clutch pedal that support the clutch master cylinder. I guess if you were a really good fabricator, you could make them but I think time wise it wouldn't make sense for what you can buy a pedal assembly for. Mine are some of the most if not most expensive on eBay. This is due to the fact that I completely remanufacture them to better than new standards. Welding on the pin for the clutch master cylinder is almost always necessary unless you get one from a super low mileage vehicle. The pin gets worn and doesn't push the rod on the clutch master cylinder as far thus making it harder to engage the clutch. Most sellers don't repair this area. If you can weld and are patient this can be repaired relatively easily.[/QUOTE] |
#18 |
Mike can you send me a PM with contact info?
#19 |
Here you go---COMPLETE hydraulic pedal assembly from an 87---375.29 shipped.
#20 |
Junior Member
returned your PM
#21 |
69vette- pm sent.
| Bookmarks |
