Old 03-21-2017, 10:44 AM   #1
6768chevylover
6768chevylover's Avatar
sm465
can anyone tell me anything about the code on the sm465 3901131(yr, output spline, etc)?
6768chevylover is offline   Reply With Quote
Old 03-21-2017, 10:49 AM   #2
6768chevylover
Re: sm465
Sorry, its out of an 85 one ton truck.. Some one is selling it and I have a 71 blazer that has a th350 w/ np205 but wanting to swap to a manual to hook up to my np205...
Old 03-21-2017, 11:14 AM   #3
snj8198
snj8198's Avatar
Re: sm465
that should be a 10 spline output shaft
im not sure if the th350 had the same adapter bolt pattern for the adapter as the manual trans but if so or not, you'll need the 8 bolt "race track" pattern adapter and change your coupler. The th350 is a 27 spline, you need a coupler with a 10 spline for the 465.
I like manuals and applaud your swap, however; i believe that if you are looking to make such a swap the NV4500 is well worth a look especially since I view the automatic to manual swap a fairly work intensive conversion.
Regardless, good luck with your project!
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 03-21-2017, 12:01 PM   #4
6768chevylover
Re: sm465
Thanks, I was gonna order the adapter from offroaddesign.com for the swap and hopefully the coupler.. I'm trying to do a same length swap so I don't have to cut driveshafts. I would like to put an nv4500 behind it but not in my budget right at the moment.. Thanks for the swap compliment!
Old 03-21-2017, 03:24 PM   #5
snj8198
snj8198's Avatar
Re: sm465
Find the adapter at a junk yard and save a bunch of money. They are very common. Buy the coupler from ORD tho.
Steve
Old 03-22-2017, 01:12 PM   #6
6768chevylover
Re: sm465
found another guy selling in my area an 85 sm465 with an np208 attached. Would this hook up to my np205 off my 71 blazer?
Old 03-22-2017, 09:51 PM   #7
snj8198
snj8198's Avatar
Re: sm465
That's a $250-400 combo. Personally, I wouldn't be afraid to run the 208 in a basic street rig. The 205 is tougher and will bolt up to the adapter but you'll need to change the coupler and probably remeasure for driveshafts. I think a new coupler can be had from ORD for about $100?? I would do some measuring and see which combo fits best with the drive shafts. Have you found a 3rd pedal set up? What about clutch linkage?
Steve
