Old 03-27-2017, 06:02 PM   #1
darcia87
1987 Chevy Truck heater hose
Hello, my 87 Chevy heater hose has a rust spot in the metal part blowing antifreeze out. Went to fix but the 1in nut that is connected to metal I'm not able to reach and get a wrench in there to loosen so I can replace the hose. Any suggestions of what I need to do? Can't afford to have a mechanic fix. Thanks
darcia87 is offline   Reply With Quote
Old 03-27-2017, 07:24 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 1987 Chevy Truck heater hose
can you post a picture of it?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-29-2017, 09:32 AM   #3
D13
D13's Avatar
We are asking because there are no nuts on normal heater hose set ups. Everything is clamps, and the 'correct' ones I have worked on have no pipes inline, only connections at the water pump / manifold and heater core. With A/C there might be a Ranko vacuum actuated valve in the hose. So a picture of your issue area would be helpful.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 03-29-2017, 09:57 AM   #4
darcia87
I will get a picture soon, been working late hours, the metal hose is connected to the intake
Old 03-29-2017, 10:10 AM   #5
Mattchu60
When you say "metal hose" are you referring to the water neck that attaches to the intake and the hose to the radiator?
Mattchu60 is offline   Reply With Quote
Old 03-29-2017, 10:38 AM   #6
darcia87
Yes, I'm having trouble loading a pic.
Old 03-30-2017, 12:32 PM   #7
Gmc.guy
Gmc.guy's Avatar
The Tbi trucks did have a hard line crimped on the end of the hose. I have cut them off and used a socket to take off. I agree they are difficult. I'll see if I can find a pic
-Cody
Gmc.guy is offline   Reply With Quote
Old 03-30-2017, 12:38 PM   #8
Gmc.guy
Gmc.guy's Avatar
http://67-72chevytrucks.com/vboard/s...ad.php?t=83905
I'll see if link works. Once it's out you can replace with a regular nipple.
-Cody
Old 03-30-2017, 12:45 PM   #9
Gmc.guy
Gmc.guy's Avatar
Most all of the Tbi engines had them, s-10, full size. Back of the intake on the passenger side
-Cody
Old 01-19-2022, 03:11 PM   #10
Hart_Rod
Hart_Rod's Avatar
Sorry for bumping an old thread, but I just replaced the heater core on my 87 Jimmy and want to update the hoses while I'm at it. Does anyone sell the OEM heater hose with the metal on the end? I don't want to take a chance on breaking the fitting off or messing up the intake by trying to remove the fitting. Thanks in advance.
Hart_Rod is offline   Reply With Quote
Old 01-20-2022, 05:26 AM   #11
Pontiac1976
Pontiac1976's Avatar
The pic on the left I think most people thought you had. because you did not say you had or were working on A/C heart core. Well that second pic looks like a A/c line to the condenser in front of the rad ( like another rad to cool A/c oil/gas liquid mix) I guessing you have the big heater case cover on the fire wall for A/C option. If the line from vapor to the condenser is what your looking for 87 try the Dealer may have them still, or your auto parts store, E-bay, scrap yard. If you go with good used lines make sure you get new a/c O-rings for the fittings.
This is a pic of a A/c heater core case Picture On the right.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 01-20-2022, 06:06 AM   #12
Corts60
Just here to tinker
Corts60's Avatar
He’s talking about the coolant hose on the TBI engine, not the ac lines.
-Just take a socket and remove the fitting in the intake. Use a 6 point socket, an impact and PB blaster so you don’t round it off. When that’s out, you can get a barb to NPT adapter and put a regular hose and clamp on it.
Old 01-20-2022, 11:28 AM   #13
Hart_Rod
Hart_Rod's Avatar
I'm worried about breaking the fitting off in the intake, that's why I was looking for other options.
Old 01-20-2022, 12:32 PM   #14
HOTFUN
HOTFUN's Avatar
I would take the hose into Napa or someone who makes pressure hoses and see if they can make you up the hose or at least a fitting end for the core side that a heater hose can be pushed onto then a clamp.
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 factory #'s V8 stepside project
'72 Cheyenne K20 50k original
'72 CST Blazer K5 owned 30+yrs
'73 Sierra swb 4x4
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 01-20-2022, 01:42 PM   #15
Just call me Sean
Just call me Sean's Avatar
If it's bad enough to break then it needs to come out.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 01-21-2022, 09:31 PM   #16
v30crewcab
v30crewcab's Avatar
those fittings rot so its good to take them out and replace them. you can do it now or have it towed when It breaks off somewhere on the side of the road.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 01-22-2022, 06:45 AM   #17
LT7A
This sounds like something a dentist would say
