Old 05-03-2017, 09:48 PM   #1
skytop
skytop's Avatar
A/C center dash vent supply hose
I have a '72. Can anyone describe or post a photo of how the center dash A/C vent is plumbed with the supply hose? How is the supply hose routed and do I need any plastic connector/adapter to connect to the vent? Thanks!
skytop is offline   Reply With Quote
Old 05-03-2017, 10:15 PM   #2
Boog
laying low
Boog's Avatar
Re: A/C center dash vent supply hose
The best I can do is post this parts diagram from the LMC catalog. Maybe it will help.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-03-2017, 10:26 PM   #3
skytop
skytop's Avatar
Boog: Great! Thanks for your illustration. I was not sure if the factory set up fed directly to the center vent or there was a "T" adapter (#9 in illustration) then bled cold air to the center vent. I can order the parts now.
Old 05-04-2017, 12:34 PM   #4
Reggler
I'm just curious as to why there are 2 hoses, coming from and going to the same vent. when I first saw inside my dash and noticed it, I thought about blocking the left side of it off, to have more room behind the radio.
Reggler is offline   Reply With Quote
Old 05-04-2017, 01:13 PM   #5
MARKDTN
That appears to be kit #16 in the catalog pic
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-04-2017, 01:22 PM   #6
davepl
davepl's Avatar
I was of the impression, and it could be mistaken, that by 1972 the switched and were only feeding the center vent from one side, with a plug on the other.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-04-2017, 01:30 PM   #7
NorCalC20LWB
My 72 has the "twin feed" to the center vent. My understanding is that if you plug one side then the air flow goes to mostly one side, either driver or passenger. It was a bit of a PITA to get both sides hooked up, but I do like the more even air flow.
NorCalC20LWB is offline   Reply With Quote
Old 05-04-2017, 01:45 PM   #8
Reggler
I could see if only 1 hose was hooked up the air would kind of only blow out left or right based on the angle of the hose going in. Would have made more sense to use the diverter in the vent like the 80's trucks have. I'll have to try plugging 1 side off the box at the T off and see what it does.
Old 05-04-2017, 02:37 PM   #9
terry b
terry b's Avatar
I just replumbed my a\c during my restoration with NOS tubing. It was tight but not impossible. Two tubes to center was stock in 1972.
terry b is offline   Reply With Quote
Old 05-04-2017, 08:35 PM   #10
jeffahart
jeffahart's Avatar
I plugged the hole on the driver side of the vent once. I wanted space as it's cramped under the dash with the stock radio. Yes, definitely, the air blows straight across to the driver and no air diverted to passenger. Now I have a retrosound to replace the stock radio... now I have enough room under my dash to park a bus, so I hooked up both ends of the vent. The stock radio is huge. I think they do make an aftermarket center vent that disperses properly with only one hose.
White K20
jeffahart is offline   Reply With Quote
Old 05-05-2017, 10:27 AM   #11
kaycee
kaycee's Avatar
UHHHHMMMM You guys did plug the top T correct #14 that way you still have air left or right and center
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 05-05-2017, 10:30 AM   #12
leddzepp
Moderator
leddzepp's Avatar
I plugged one side of the center vent years ago. It improves the volume coming through the center vent. The cab is so small that it cools the truck regardless if you do it or not. I did it for more room installing the radio and less clutter.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-05-2017, 11:50 AM   #13
jeffahart
jeffahart's Avatar
I don't get it! On my center vent if you feed only one side, the opposite side gets the air stream. What's it matter which end of the 'T' gets plugged?
White K20
Old 05-05-2017, 04:09 PM   #14
kaycee
kaycee's Avatar
The top T= #14 only supplies the center vent 1 hose on each side of vent plug 1 side and all the air goes to the 1 hose for the center vent. The bottom t or cross puts air to the pass. and drivers side vents, the top of the cross goes to the center vent. Plug one side of T # 14 and it puts more air to the vent.
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 05-06-2017, 03:46 PM   #15
skytop
skytop's Avatar
After some searching, I went with the new style single inlet fixture to connect to the center dash air vent. It flows far more volume of cold air. The fitting is available at the most of the major vendors but I purchased it from Brothers:
CVUG072 67-72 CENTER A/C VENT UPGRADE .
1972 C10 SWB, 1970 Corvette, 2017 Grand Sport
