Old 10-21-2003, 06:33 PM   #1
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Opinion's on LIFT spindles??
My daily driver is a 2wd 94 c2500. I have a 3" body lift and 33's on it. The problem is that I need a little more clearance in the front and have already used a cushion spacer from Daystar. Has anyone tried lift spindles?? Are there any drawbacks?? Chassis tech which usually is a AIM part that no one is to fond of has a set for $300 which is about $200 cheaper than a fabtech piece. I do not use this truck off road at all, it was just something that I did cause it looked cool. Thanks
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 10-21-2003, 06:42 PM   #2
Blaze
phanton can you not use 1'' or 2'' lift coil
springs.iIt might be cheaper.
Thanks blaze
'91 K5 Blazer (ex 4x4), '91 2WD S10 Blazer and"97 4WD Yukon
Blaze is offline   Reply With Quote
Old 10-21-2003, 06:47 PM   #3
phantom dually
I might be able to do that. I hate pulling springs. They suck!! I think you may have run a moded upper a arm to do this Im not sure. I can put in a spindle and nevertouch the spring. This would give me a op to do brakes and repack bearings on the 48K mile truck.
Old 10-21-2003, 09:36 PM   #4
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
I upon using a lift coil on the front of your truck, Assuming you have the factory arms/ect, the geometry will change and it wont be very fun to drive (turn corners).
Go with the lift spindles!!! A friend of mine was running a '98 Ford F150 2wd with a complete Fabtech kit. It was very very very fun out in the desert
I've never heard of Chassis Tech, but I KNOW that Fabtech makes some quality parts. Is it worth the extra $200?! Maybe... maybe not...
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 10-21-2003, 09:47 PM   #5
phantom dually
Chassis tech makes some parts for Aim which is known for gouging people on shipping. I used a set of spindles one time from them and had no probs at all. This truck is a bit bigger and I do not want to have a problem. Like I said before it is all just for looks and is 2wd. Thanks
Old 10-22-2003, 02:08 AM   #6
1FaastC10
1FaastC10's Avatar
actually, when i bought from shAIM, my CT parts were very cheaply shipped. i bought a set if 2.5" drop spindles, and a shackle and hanger kit. the problems i ran into were the quality of the products. some of the bolt holes didnt line up with the holes in the frame, and the spindles required some serious modification to the backing plate. i called their customer service line, and they were no help at all. actually treated me like i was retarded or something. i know several people who have FabTech products on thier trucks, and they all say they're great.
1FaastC10 is offline   Reply With Quote
Old 10-22-2003, 07:55 AM   #7
Linus0014
Guest
Posts: n/a
I'm putting the fab tech 4'' long travel, which includes dual shock brackets, upper/lower control arms, ball joints, engine cage, 3''coils, billet a arm cross shafts, tie rod ends and all the little things on my 72" GMC, so we'll see what happens.
Old 10-24-2003, 06:46 PM   #8
z71runner
nothin to say
z71runner's Avatar
I have an 88 silverado2wd 3500 series with the fabtech 7.5inch lift kit. I would recommend the spindles from fabtech which will give you 4.5 inches of lift up front. They are the easiest way to lift without messing up any other suspension factors. They are moderately priced for what you get. Fabtech is by all means not meant for serious offroading, but it gets the job done if you want the look of a lifted truck.
1988 3500 Chevy Silverado 454
7.5 inch lift on 35 inch tires
z71runner is offline   Reply With Quote
