Old 06-05-2017, 05:11 PM   #1
skinnan
Help with power steering hose
ok, so it appears that my 1972 c-10 had an 86 305 installed in it. The pressure side power steering hose has a lovely leak in it. I had ordered a hose for the 72 before I realized the difference. Any clues on what i can do to get a hose to fit? Thanks for all the help in advance.
skinnan is offline   Reply With Quote
Old 06-05-2017, 05:44 PM   #2
74baggedbug
Re: Help with power steering hose
You can take the ends of your old hose and have a hydraulic shop make you a hose
74baggedbug is offline   Reply With Quote
Old 06-05-2017, 05:45 PM   #3
demian5
demian5's Avatar
Take the hose off and a good parts place can figure something out using pictures.
Also, if you want to help yourself, Rock auto has good pictures, you could look at all models and years and find one that looks like it. they should all screw on the same way, I don't know why the year and displacement of the engine should matter, they both have flare nut ends.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 06-05-2017, 05:52 PM   #4
Boog
laying low
Boog's Avatar
Does the new hose for a 72 not thread into the pump or sector? The early 70s trucks used flared hose fittings. The newer ones used an oring fitting. You may simply need to buy one for an 86 or so truck. Take your old one with you to match up at the parts store.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-05-2017, 05:53 PM   #5
skinnan
Guess I was under the assumption, based on what I've been reading here, that the older steering gear was standard thread and the newer pump was metric!?!
Old 06-05-2017, 05:54 PM   #6
skinnan
The hose for the 72 doesn't even reach back and around to where the 86 pump needs it to be...
Old 06-05-2017, 05:55 PM   #7
skinnan
great idea....thanks. Need to find one of those shops
Old 06-05-2017, 05:57 PM   #8
Boog
laying low
Boog's Avatar
Some aftermarket hoses need to be "adjusted" to fit better. Be careful though and dont crimp it if you do. Does the old one fit well?
Boog
primer is finer
Old 06-05-2017, 05:59 PM   #9
skinnan
the old one is a Frankenstein...not even sure how this guy got it to work in the first place. I should post a picture.
Old 06-05-2017, 06:03 PM   #10
Boog
laying low
Boog's Avatar
Well the proper hose isnt exactly a great fit either. You have to loop it around to reach the back of the pump. Id post a pic if i had one handy.
Boog
primer is finer
