Old 06-14-2017, 07:58 PM   #1
Soyuz008
Mid Chasis Gas Tank
I needed a new gas tank anyway so I wanted to move it under the box. I did not want to mount it behind the axel because that is where I plan on putting the spare tire. Since I have the service box instead of a standard bed, this gave me room to put the tank in front of the rear axel.
A tank from a 1967 Mustang fit perfectly in this area, just needed a cradle to mount the tank to the frame. I welded a side filler neck onto the tank and ran the fill tube into the driver side storage bin. Finished it off with a magnetic fuel door and push through gas cap.
It will still many months before I drop in a pump and get the engine fired up, but one more task checked off the list.
Soyuz008 is offline   Reply With Quote
Old 06-14-2017, 08:03 PM   #2
63frankintruck
Re: Mid Chasis Gas Tank
nice job, I wonder if that would work for my 63 long bed fleetside?
63frankintruck is offline   Reply With Quote
Old 06-14-2017, 08:20 PM   #3
Lugnutz65
Lugnutz65's Avatar
Very nice job!
I have a 1963 short bed fleet side. I also have a 1965 short bed step side. I refuse to install a tank between the frame rails at the back of the bed because I want to keep my spare tire there (under the bed).
I've been kicking around the idea of putting a gas tank in the bed just behind the bed header panel. Basically, install a tank between two header panels at the very front of the bed. It would get the tank out of the cab but would only sacrifice about 1 foot of bed length. I think it'd be more easily accomplished in a fleet side bed since it is wider.
The tank would gravity feed just like the tank that is inside the cab. For a fleet side bed, you could even use the original tank since it will fit between the bed sides.
Just thought I would share my idea.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 06-14-2017, 10:38 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I also banged around the idea of putting the tank there.
As you all, I want to put my spare behind the axle.
My other thought was to go with one of those skinny spares rather than a full size tire.
66 C20 Service Truck:
Old 06-17-2017, 08:31 PM   #5
richards72chevy
richards72chevy's Avatar
[QUOTE=Soyuz008;7967601]I needed a new gas tank anyway so I wanted to move it under the box. I did not want to mount it behind the axel because that is where I plan on putting the spare tire. Since I have the service box instead of a standard bed, this gave me room to put the tank in front of the rear axel.
It will still many months before I drop in a pump and get the engine fired up, but one more task checked off the list.[/QUOTE Good idea.
richards72chevy is offline   Reply With Quote
