![]() Join Date: Jun 2015
1961 bellhousing question
I have a chance to buy this "big truck" for very cheap. All I would be interested in would be the bellhousing. Would this work to put a 292 in a 1961 C10, with a 3 speed? It looks like the mounts for the transmission are on the bellhousing? Thanks.
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
Re: 1961 bellhousing question
yep. set up for hydraulic clutch.
what was in front of it a v8 or i6
ron |
That is the same bell housing I worked with. You can get the rear motor mounts just about anywhere and some of those bell housings will go for pretty good money on ebay if you change your mind and decide not to use it.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
Thanks for the replies everyone. The truck is an 8 hour drive from me, so I have not seen it in person. It's a liquidation type situation, I am looking at a few vehicles on the property. Before I say yay or nay, I am just trying to make sure this is the bellhousing I need. Info on what the engine was is not available. Here is a pic of the whole truck.
So, forgive my ignorance, but I am not sure the bellhousing out of a big truck is the same as one out of a c10? In these 2 pictures, looks like the one I am looking at has extra mounting "ears" circled in red, compared to this image I pulled off the internet that came from a c10.
if it is a 60-62 and had a 235, 261 or a 270 i6 then it will only bolt to those engines. if it was a v8 bellhousing then it will bolt to the later engs., sbc,bb, 230,250, and 292.
if that truck used a 5 speed the hole where the front input brg cover may be larger(thought I am unsure of this.. someone else may comment on this). that can be remedied though with a machinist and a lathe ron |
If the bellhousing is the same between big truck and c10, I am set. If the bellhousings are somewhat different, what modifications would I need to do to my truck to use the big truck bellhousing?
Picture of interior.
#10 | |
if it has a SM420 in it: it will be the same size. ron Last edited by padresag; 06-21-2017 at 12:54 PM. |
looks like a V8 bell to me. the 6cyl ones were a little different shaped and had an inspection cover on the trans side.
1961 chevy K10 my build is------------61K10 build |
Thanks everyone.
| Bookmarks |
