Old 07-11-2017, 12:29 PM   #1
Devil Pup
Devil Pup's Avatar
In need of some manifolds
Hey guys I've searched and cant seem to find this part number. I am swapping a 2000 tahoe 5.3/4l60e combo into my 69 C20 and am looking for some Trailblazer SS Exhaust manifolds. Found these on ebay but the part numbers dont seem to line up. Guys ad say trailblazer 6.0 but not much more. Can anyone confirm if these are TBSS or if not what they are and will they work? Thanks in advance!
Devil Pup is offline   Reply With Quote
Old 07-11-2017, 01:24 PM   #2
Devil Pup
Devil Pup's Avatar
Thumbs down Re: In need of some manifolds
Wow sorry to waste anyones time. I think these are stock truck manifolds like what I already have!
Old 07-11-2017, 01:38 PM   #3
Rich84
Rich84's Avatar
I think you are right..They look like truck manifolds.
Rich84 is offline   Reply With Quote
Old 07-11-2017, 02:03 PM   #4
Devil Pup
Devil Pup's Avatar
thank you for the response, maybe next time ha
Old 07-11-2017, 05:44 PM   #5
LeesTruk
All of the V8 Trailblazers (both 5.3L and 6.0L), as well as Buick Raineer, and GMC Envoy, use the same manifolds, so don't restrict your search to just the SS models. Also note that Dorman Products makes a rt. side manifold (but not a left. Don't know why). These manifolds are VERY similar to the truck pcs. (even the exhaust pipe flanges are the same) but tuck in closer to the block by about an inch or so. I used the Dorman manifold and a Raineer manifold for my swap
LeesTruk is offline   Reply With Quote
Old 07-11-2017, 06:12 PM   #6
Devil Pup
Devil Pup's Avatar
Good to know. I will expand my search. So this may be a dumb question but can I run a truck manifold on one side and a different one on the other? I only have slight interference on one side. other than looks will it have any ill effect on the motor?
Old 07-12-2017, 04:38 AM   #7
dec010974
dec010974's Avatar
Hello Devil Pup. I hope all is well. If you only have a little interference, why don't you notch the frame in the area of the interference? I used trailblazer ss manifolds on my LSx swap, 1971 c10, and I had to notch the frame. I'm not a professional but in some cases, the LSx swappers that used the ss manifolds, without notching the frame, were able to accomplish this task due to the engine's installment being closer to the cab/fire wall. The c10 frame seems to taper outward, as the frame extends towards the firewall. Let me know if I'm wrong. Notch the frame or heat it with a torch and bend it. Good luck. Clark.
dec010974 is offline   Reply With Quote
Old 07-12-2017, 05:45 AM   #8
72MARIO
72MARIO's Avatar
2010 up camaro fit great as well
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 07-12-2017, 11:54 AM   #9
Devil Pup
Devil Pup's Avatar
I thought they were a clear all type application. Maybe I'll look into notching or heating the frame to move it for clearance.
Do these have the same 3 bolt pattern as my stock LM7 collectors? Also can I run a truck manifold on one side and a camaro one on the other? other than looking funny will it cause any issues?
Old 07-12-2017, 05:43 PM   #10
ls1nova71
ls1nova71's Avatar
2010-up Camaro manifolds have a 2 bolt flange, not the same as trucks. You can use different ones on each side, it wont hurt anything. Where are you located? I can't believe that the TBSS or equivalent are so hard to find?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-12-2017, 06:02 PM   #11
Devil Pup
Devil Pup's Avatar
A different one on both sides might work out because it only hits on the driver side. and im in Riverside California. Ive never seen a trailblazer SS in the junkyards and most the LS are picked to pieces when you do find em. Searched the local craigslist and haven't found anything.
Old 07-12-2017, 08:07 PM   #12
MIKESAD50
have you tried car-parts.com or LKQ?
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 07-12-2017, 11:13 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
car-part.com (no S) is the one you want to use to search wrecking yards.
TBSS headers clear most swap frames. Consider the variables tho: recipient vehicle, original motor position, which type of stands/perches the old motor used and which position they are in if applicable, which type of swap mounts are being used, what mount material (poly vs rubber). Each of these changes the relationship between frame and manifold.
If an ultra-low clearance manifold is what you need, I believe Hooker also makes a low clearance log manifold very similar to the TBSS manifold for that type of fitment.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-13-2017, 05:14 PM   #14
Devil Pup
Devil Pup's Avatar
The pick a parts I go to are LKQ, But I believe they strip some parts and sell em on the web also. I will check out Car-Parts.com. I've looked into them before but haven't actually purchased from them. Can they ship or do i have to go to a local place for pickup?
Old 07-13-2017, 06:03 PM   #15
mongocanfly
mongocanfly's Avatar
Carpart.com is just a parts listing for junkyards...they don't actually sell anything..if you find something on it you would have to contact the lister and set up buy/ship...think of it as craigslist for junk yards..
Old 07-13-2017, 06:38 PM   #16
Devil Pup
Devil Pup's Avatar
Got ya. Ill look into them!
