Old 07-12-2017, 05:56 PM   #1
ApacheIvan
ApacheIvan's Avatar
Hiding a multitude of sins! Spray Paint.
I don't know if I am the only guy that through the years decided it was easier to throw a coat of flat or satin black over something to dress up the engine compartment a bit, even over dirt and grime. Well as I get older and the 72 gets more valuable it is time to do it right, or at least better. So I have been working on the airbox first. After seeing a few restored, I see it is not black, it is more grey with texture like fiberglass, so I am using a product and scrapping all the old paint off while it is still in the truck.
I wanted to share with you some pretty good spray paint remover that is working quite well.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I spray it on and it softens the paint up and does not harm the plastic, or fiberglass that is under it, I use a scrapper and it peels right off, sometimes I have to use it a few times depending on how thick the coats are, but typically, spray, wait 15 min and scrape and it comes off in sheets.. Just an FYI!
Dale - ApacheIvan
1972 Chevy Custom/20 Custom Camper Highlander
http://67-72chevytrucks.com/vboard/s...d.php?t=740479
Original Owner
** Do you have a 1972 Plaid Pickup?**
ApacheIvan is offline   Reply With Quote
Old 07-12-2017, 07:44 PM   #2
Jason Banks
Jason Banks's Avatar
Re: Hiding a multitude of sins! Spray Paint.
That's good to know. Previous owner of my truck thought it was a good idea to spray everything, and I mean everything, under the hood with spraypaint. That's why I recently tore the front end down to repaint the firewall and inside fenders, etc....
Jason Banks is offline   Reply With Quote
Old 07-12-2017, 09:29 PM   #3
bill3rail
bill3rail's Avatar
I love this site! I started cleaning an air cleaner I recently picked up, step inside and log on to 67-72 and Bbamm! There is a thread on paint remover!
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 07-12-2017, 09:31 PM   #4
bill3rail
bill3rail's Avatar
Jason,
What air cleaner is that? Or is the picture misleading showing it notched around the brake booster?
Old 07-12-2017, 09:48 PM   #5
ApacheIvan
ApacheIvan's Avatar
This stuff worked pretty well and is non-toxic and not eating away at the parts the paint is stuck to. My air box that houses the evaporator came out very nice..
Dale - ApacheIvan
Original Owner
Old 07-12-2017, 10:22 PM   #6
72chevynut
72chevynut's Avatar
Wow! That looks great, good job! I know the cleaner helped but that isn't just a spray and wash job. Thanks for sharing the info and pics.
Michael
72chevynut is offline   Reply With Quote
Old 07-12-2017, 11:27 PM   #7
Jason Banks
Originally Posted by bill3rail View Post
Jason,
It's a custom air cleaner modification by a previous owner. Probably whoever added the 3/4 ton booster and master cylinder to my 1/2 ton truck. Which makes the brakes work TOO good. The rear will lock instantly if you jump on it.
When I got the truck. It looked like it had been cut with a torch and the part on the inside brazed back in backwards. I will try to get an inside pic, but it fits the normal air filter fine. I did straighten up the cut lines with a belt sander and worked on the brazed in part with a hammer, file, sander and added some bondo....so It looks much better than when I got it.
