box is off
Box is off. Frame and cross members look great
Re: box is off
As a side note. When i first looked at it I thought WTF. That centre crossmember that the drive shaft linkage thingy ( can't remember the name of it )is attached to is installed crooked from the factory. For a second I thought the thing was bent. LOL
![]() Join Date: Jan 2011
Re: box is off
In that picture the entire truck looks out of square. All the cross members should be square with the frame except the one behind the rear axle. Is the drive shaft thingy the center support bearing?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#4 | |
Re: box is off
Cross ways, up and down etc. The picture is playing with the eye on this one. Everything was with in 1/4 inch or less with my tape measurement. I figured 1/4 inch was executable for 51 year old frame. But you got me wondering so I went out and remeasured again. No more than 5/8 diff. Just in the back part so maybe a very slight bend the one way. The frame is going in to be straightened so they should be able to double check that and bend it back. I have never dealt with a bent frame. I have been told its all repairable. Im hoping thats true. Last edited by Harleymike; 08-22-2017 at 07:06 AM. |
![]() Join Date: Aug 2013
Re: box is off
its just the picture angle. whats your plans for the overload springs???
Re: box is off
Re: box is off
Re: box is off
Re: box is off
Re: box is off
Re: box is off
the only function that i know of they provide is extra load capacity as far as traction i havent heard of that being a normal fuction. they may provide traction if there is a heavy load causing the axle to be planted firmer, but i learn something everyday
#12 | |
Re: box is off
Maybe i'll pull them off then. It won't be used to haul anything heavy ever again. What are they worth. Or are they even sellable. |
#13 |
Re: box is off
i bought mine off a forum member for say $150 plus maybe $100 to ship bout 3yrs ago well you can always put them up for sale and see...
#14 | |
Re: box is off
Why did you want them for your truck. |
#15 |
Re: box is off
