Old 08-22-2017, 02:01 AM   #1
Praxiss454
Praxiss454's Avatar
Mystery Nut/Bolt Identification?
Hi all,
Pulled these off of my truck somewhere, and thought enough of it to set them aside. Now I can't remember where they are from or if they're important at all. The only things I've done to the truck recently that I can recall are taking the bed off the frame and putting in new bed wood
Any idea where the hell they're from and what they're for? There are two nuts, two bolts, and those two floating square things that are rounded on one side.
1965 GMC 1000 SWB Fleetside L6 230 - SOLD
Thanks everyone for the help over the years.
Praxiss454 is offline   Reply With Quote
Old 08-22-2017, 07:56 AM   #2
pimpston65
pimpston65's Avatar
Re: Mystery Nut/Bolt Identification?
they dont look like anything ive seen. first. most if not all spoked washers have the spokes on the outside. second. the one bolt is a safety wireable nut, only seen those on driveshaft bolts but not on C/K 10 versions. third. the sqaure nut isnt used on these trucks other then areas that its welded in-place kinda like a "captured nut" but with a weld vs a cage.
pimpston65 is offline   Reply With Quote
Old 08-24-2017, 10:07 PM   #3
Praxiss454
Praxiss454's Avatar
Thanks I am really puzzled. I thought enough of them to set them aside, but not enough to remember where the hell they came from. The square nuts are slightly rounded on one face, and I seem to remember them being used to hold something up.
Old 08-25-2017, 12:27 AM   #4
pimpston65
pimpston65's Avatar
i would still keep them, cuz you never know...
Old 08-25-2017, 07:42 AM   #5
urmyboyblue
The washers are internal tooth lock washers or sometimes called star washers. I don't think that they were used on these trucks at all. The square nuts- I think are used somewhere but I can't really remember. You said they float,so they may be a size larger than the bolts. The bolts are just random bolts- can't tell what grade. Clean em up and throw them into your spare hardware bucket. You might need them later for something.
Just a side note about disassembling things. Now that every phone has a camera, it is free to take pictures. I always take pictures of things I have never disassembled so that I can put it back together the same way. And you can take as many as you want- but you will always wish you had taken more.
urmyboyblue is offline   Reply With Quote
Old 08-25-2017, 11:25 AM   #6
Llay R. Rac
Llay R. Rac's Avatar
they seem familiar to me but not from my truck, but maybe from a '70 El Camino i rebuilt 25 years ago. Maybe AC compressor related?
1965 Suburban, 2 wd.,292, 4-speed.
proudly owned and operated since Valentines day 1969.
Llay R. Rac is offline   Reply With Quote
Old 08-25-2017, 12:43 PM   #7
61K10
61K10's Avatar
One bolt id fine thread and the other is course. what size? 3/8 or 5/16? square nuts? inside on firewall?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-28-2017, 11:55 PM   #8
vetnat
Hey, I came across the internal star washer while parting out a 63. On the wiper switch, behind the bezel.
1961 GMC half ton, short step, Canadian model. Just starting work on it.
vetnat is offline   Reply With Quote
Old 08-29-2017, 02:05 PM   #9
Praxiss454
Praxiss454's Avatar
I just wonder what, on the bed / back half of the truck, they could have been used for. I feel like something was hanging from them. One of the floating bed crossmembers? In any case I guess they're not crucial as the truck hasn't fallen apart!
