Old 08-23-2017, 05:34 PM   #1
SeanB242
SeanB242's Avatar
the bad, then the good
Long story short, after many hours of work by my son and I, there was an accident. Thankfully he wasnt seriously injured.
IMG_0358 by Sean Blackwell, on Flickr
After a few weeks of searching, I found this unit.
Untitled by Sean Blackwell, on Flickr
We are going to use the cab on his frame, and I am taking the short bed frame to start my own project. Lots more work ahead of us. Just so happens this cab has an original radio delete plate in it. Are these things worth anything? just curious how rare they are.
SeanB242 is offline   Reply With Quote
Old 08-23-2017, 06:31 PM   #2
toolboxchev
Re: the bad, then the good
They are all worth something to somebody, the ShortBeds pull a better dollar for the driver, non-enthusiast crowd.
I like a truck that works like a truck.
toolboxchev is offline   Reply With Quote
Old 08-23-2017, 07:44 PM   #3
yuccales
yuccales's Avatar
Glad your son was not hurt to bad! Got to be pretty bad to finish off one of our trucks. It will rise again!
yuccales is offline   Reply With Quote
Old 08-23-2017, 07:57 PM   #4
trac209
Glad he wasn't hurt bad,the rest is just metal. The replacement looks like a solid truck
trac209 is offline   Reply With Quote
Old 08-23-2017, 09:03 PM   #5
SeanB242
SeanB242's Avatar
Very thankful he wasn't hurt to bad, thanks guys. We are stripping everything out of the wrecked cab. Under the dash there are 3 bolts on each side that bolts the dash to the side, bottom of the A pillar. I took all those out thinking i may be able to save the dash area out of the cab. The sides will wiggle back and forth but it seems the top area under the windshield is made together. Does anyone know if this comes apart to get the dash out?
Old 08-23-2017, 09:07 PM   #6
clay68c10
clay68c10's Avatar
Good he wasn't hurt bad, too bad about the truck.
Look on the sale section, the radio deletes are worth a couple bucks. I always thought it would be neat to use one as a hinged cover for an aftermarket radio.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 08-23-2017, 09:08 PM   #7
clay68c10
clay68c10's Avatar
You will have to cut under the dash cover to get it out. Or drill out a million spot welds on the windshield flange.
13 Tahoe LTZ
Old 08-23-2017, 09:18 PM   #8
SeanB242
SeanB242's Avatar
ok, thanks clay68. I will look at that
Old 08-23-2017, 09:38 PM   #9
clay68c10
clay68c10's Avatar
Under the dash pad
13 Tahoe LTZ
Old 08-23-2017, 10:06 PM   #10
SeanB242
SeanB242's Avatar
Sweet. thats the plan then i guess. ill cut it out tomorrow.
Old 08-25-2017, 09:11 AM   #11
SeanB242
SeanB242's Avatar
Another question. This short bed frame I got, I noticed the cross member that the panhard bar is bolted to is in the frame at an angle. i dont remember the 68 I had 20 years ago being like that. Its mounted with the big factory like rivets so I don't think its been moved? Anyone?
Old 08-25-2017, 03:06 PM   #12
CharlieBrown
CharlieBrown's Avatar
angle is normal....on long bed frames too
1972 Cheyenne Super..owned since 1978
1972 Surburban 4x4
1972 Cheyenne 4x4 3/4 ton.....sold
1972 Cheyenne 2wd...named Death Row
CharlieBrown is offline   Reply With Quote
Old 08-25-2017, 03:10 PM   #13
SeanB242
SeanB242's Avatar
ok thanks. i figured it had to be with the original rivets in it. just dont remember seeing it before
Old 03-04-2018, 10:51 PM   #14
SeanB242
SeanB242's Avatar
Finally warm enough to get started again. Replacing full floor pan, rockers, and corners. Block has been hot tanked. Going to pickup tomorrow.
Old 03-04-2018, 11:25 PM   #15
keel056
If the windshield has to come out, I would go ahead and drill the spot welds for the dash. very easy and only takes about 20 minutes.
keel056 is offline   Reply With Quote
Old 03-04-2018, 11:47 PM   #16
SeanB242
SeanB242's Avatar
Yep. Already did that.
Old 03-05-2018, 12:08 AM   #17
Husker
Husker's Avatar
Glad Everyone is OK, That's all that really matters.
You will have to keep updates on the floor Install.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 03-05-2018, 12:23 AM   #18
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Good to see this project going again!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 03-05-2018, 02:02 AM   #19
SeanB242
SeanB242's Avatar
I guess technically the first project should have been heat for the garage. Hahaha
Old 03-23-2018, 06:55 PM   #20
SeanB242
SeanB242's Avatar
Little more done today. Old floor out. Edges where it mounts cleaned up. Holes for spotwelds drilled. Need some more sheet metal parts before we insert the floor.
Old 03-23-2018, 07:24 PM   #21
68Gold/white
Replacing entire floor is a lot of work, but the ONLY way to go!!!
Carry on!!!
68Gold/white is offline   Reply With Quote
Old 04-14-2018, 01:52 PM   #22
SeanB242
SeanB242's Avatar
Little frame cleaning today. Motor is about back together. Slowly but surely.
Old 04-29-2018, 03:15 AM   #23
SeanB242
SeanB242's Avatar
Last weekend we set the motor in because he was dying to start it. Today we got the floor pan back in. Man these aftermarket body parts are a pain. Of course I’m am NOT a body man. The method I found that’s working best is making relief cuts to areas on one end and get it attached the work your way down to the other end. Looks ok now but who knows when we go to attach front clip and doors. Set the cab on frame for easier access. At some point someone cut 2 different squares into the firewall, we are assuming to get to the tranny bolts?
I can’t even put into words the “welding” that they attempted. LOL so thats next before the cab get moved into position.
Old 04-29-2018, 09:28 PM   #24
BCOWANWHEELS
if it works as good as it looks you,ll be in good shape. don't start that engine without coolant................
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 04-29-2018, 10:18 PM   #25
SeanB242
SeanB242's Avatar
Couldn’t resist. I’m glad I’m way past this point in my welding skills. Lol
