Old 08-23-2017, 07:43 PM   #1
Coalkracker
Correct alternator bracket
What is the correct style alternator bracket for a 1970 c10 without power steering or a.c. My local parts stores don't list an own style just chrome ones of all different styles. My truck was missing it when I purchased it so I don't have anything to go by.
Coalkracker is offline   Reply With Quote
Old 08-23-2017, 07:46 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Correct alternator bracket
V8 or L6?
If V8, BBC or SBC? Long water pump or short water pump?
Old 08-23-2017, 08:18 PM   #3
Coalkracker
307 v8 with short water pump
Old 08-23-2017, 08:43 PM   #4
70cst
70cst's Avatar
Bump ... the answer is?
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-23-2017, 09:42 PM   #5
'68OrangeSunshine
Here's the 350 V8 SBC w/short water pump in my '71 GMC Jimmy. I have one of those chrome thingies, but it works. The OEM was the same but black.
Old 08-23-2017, 09:48 PM   #6
Coalkracker
Thanks for the resonse... My intake manifold doesn't have a threaded hole for the bracket though. It almost appears that it should only bolt to the head for the upper bracket and possibly the block for the lower bracket.
Old 08-23-2017, 09:53 PM   #7
Coalkracker
You can see the 3 holes in the driver side head
Old 08-23-2017, 09:53 PM   #8
Mike C
Mike C's Avatar
It should look like this:
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-23-2017, 11:51 PM   #9
B. W.
B. W.'s Avatar
X2 - not a great picture but here it is anyway:
(I know, this one has P/S)
B. W. is offline   Reply With Quote
Old 08-24-2017, 12:58 AM   #10
'68OrangeSunshine
I guess there's more than one way to skin a cat. Looks like you need one like MikeC 's.
Old 08-24-2017, 06:43 AM   #11
Coalkracker
I like the one that Mike c posted but it's a little pricey at 85 dollars. How does the bottom mount on yours? Does the bracket bolt into the block below the heads or is it all one piece?
Old 08-24-2017, 08:17 AM   #12
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Correct alternator bracket
A lot of GM 60's model car will have these brackets if they have a V-8 in them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-24-2017, 11:42 AM   #13
VetteVet
Msgt USAF Ret
VetteVet's Avatar
jesus! $85 bucks, I better go clean mine up.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-24-2017, 04:03 PM   #14
Andy4639
Old member
Andy4639's Avatar
Talking Re: Correct alternator bracket
Old 08-25-2017, 08:25 AM   #15
Mike C
Mike C's Avatar
I've been buying parts for my Corvette to put a big block in it with power steering. The $225 that bracket costs is expensive. Truck parts is cheap! Relatively speaking at least.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 08-25-2017, 12:41 PM   #16
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I'm confused. The bracket you posted bolts to the front of the cylinder head and your 64 heads aren't drilled, or are they, My 74 heads are drilled, but if yours are not then you'll need a different bracket. If you're putting in a BB the bracket probably won't be the same anyhow. ???????
VetteVet
Old 08-25-2017, 08:44 PM   #17
Mike C
Mike C's Avatar
The picture I posted was just the most clear I could find on the web of what he wanted. As I said above, swapping a 427 into my small block 64 and having to piece together the accessory drive. That along with building another 427 for my 69 short step and learning all of the parts needed for a truck conversion I am the guru of big block short pump pulleys and brackets now... And I have paid handsomely for that knowledge.
I'm just commenting about price referencing the 'vette bracket. There is nothing the same about the Corvette Big Block power steering / alternator bracket shared with anything else. Because of how compact the space, the PS is driven from the crank, then the second pulley groove on the PS drives the alternator. The alternator is not directly connected to the crank pulley on a big block Corvette.
Unlike other big block PS setups that drive from the 3rd groove (Camaro, Chevelle, Truck) the 'vette BB drives from the 2nd groove pulley. The 65-68 Chevelle uses the same PS/alternator setup as the 68-72 trucks. Mostly.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 08-25-2017, 08:58 PM   #18
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Ok thanks for the clarification.
VetteVet
Old 08-25-2017, 08:59 PM   #19
Andy4639
Old member
Andy4639's Avatar
Vette,
I cleaned this set up and installed on my 64 SS Impala.
