Old 08-29-2017, 07:33 PM   #1
1BAD65
Carter m6626 fuel pump line sizes ???
Hey guys
Need to know what size lines this pump needs.
1. In (3/8??)
2. Return
3.To Carb
1BAD65 is offline   Reply With Quote
Old 08-29-2017, 08:01 PM   #2
ray_mcavoy
Re: Carter m6626 fuel pump line sizes ???
Yes, I believe the inlet of that pump takes a 3/8" ID hose. The return line is 1/4" ID hose. And the outlet to the carb is configured for a flared 3/8" OD steel tube with a 5/8"-18 inverted flare nut.
ray_mcavoy is offline   Reply With Quote
Old 08-29-2017, 08:53 PM   #3
1BAD65
Originally Posted by ray_mcavoy View Post
yes, i believe the inlet of that pump takes a 3/8" id hose. The return line is 1/4" id hose. And the outlet to the carb is configured for a flared 3/8" od steel tube with a 5/8"-18 inverted flare nut.
thank you !!!! Ray!!
