Old 09-01-2017, 06:59 PM   #1
tim71
tim71's Avatar
Wiper transmission arm question
Is there a trick to getting this clip to secure itself to the post that holds both wiper transmission arms? I've spent a lot of time on what is probably a 20 second job.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 09-01-2017, 07:28 PM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Wiper transmission arm question
Insert the clip into the pin from the top. Should be real easy. Perhaps the arms aren't assembled right? Anyway, it should look like this.
Incidentally Tim, if you haven't got one of these or similar, this tool is the stuff for pulling & attaching wiper arms. It will make your life easier and is damage prevention. https://store.snapon.com/Window-and-...l-P636287.aspx
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-01-2017, 07:35 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
The clip in your pic is missing the retainer turn up...it may fit on but it will fall off when you start using it.
The bottom photo clip shows the little bend on the end that retains the clip.
AussieinNC is offline   Reply With Quote
Old 09-02-2017, 07:17 AM   #4
tim71
tim71's Avatar
Thanks for the help, I can see how to install it now.
