Old 09-18-2017, 10:27 PM   #1
twoskies
twoskies's Avatar
pulley issues
Hello
ive got a 1972 c10, originally a 350/4 bolt main
po had stuck a broken 305 in it when i bought it, took it out really quick
found a 1979 elcamino 350/4 bolt main(got a great deal on it, Target motor, about 10000 miles on it, chrome valve covers, already painted orange, and hei ignition)with a little help from my friends
ok so here's the issue, i noticed when i bought it the alternator belt was slightly off, its about a 1/4 inch,alternator is on left hand side of motor, original motor was alt on right im assuming
so when i got the motor in, have not fired up yet, but heard run when bought
ive got power steering also,
the alt lines up perfectly with the water pump, but not the crank, same for the power steering, lines up perfectly with the water pump, neither lines up evenly with the crank pulley
laid a straight edge across the power steering pulley, seems the crank pulley needs to go back towards the motor about 1/4 inch(yes , crank is seated)
any help appreciated
couple big car shows and swap meets this weekend, so i can probably find pulleys that i need, just dont know what to look for
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 09-18-2017, 10:35 PM   #2
ho70
ho70's Avatar
Re: pulley issues
Shim the other pulleys out
ho70 is offline   Reply With Quote
Old 09-18-2017, 11:16 PM   #3
snipescastle2
snipescastle2's Avatar
Talking Re: pulley issues
I had a similar problem, these trucks mostly came with the "Short" water pumps, hence the long flat curved upper alternator bracket. I decided to run a "long" style pump and the brackets are obviously different, but the lower crank pulley wouldn't line up and belts would walk off the grooves. I finally went to a salvage yard and got the matching set of pulleys and brackets, seems the pulleys I had originally had only worked with the short pump, or got mixed up with other pulleys sometime ago....I got the entire set of pulleys and brackets off of a late 70's Camaro, everything works as it should now.
Hope this helps!
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 09-19-2017, 12:41 AM   #4
kwmech
Re: pulley issues
Originally Posted by snipescastle2 View Post
I had a similar problem, these trucks ALL came with the "Short" water pumps.............
I've got a ton of pulleys if you end up needing something, How about posting up a couple of pics showing what you are working with
Old 09-19-2017, 07:23 AM   #5
twoskies
twoskies's Avatar
Re: pulley issues
Thank You everyone
i dont like the idea of shimming the pulleys but might have to,
ill try the 70 camaro pulley idea
incredible couple car shows and swap meets this weekend
Ducktail Run, gas city,in
and
James Dean , Fairmont,in
ill try to get and post pictures tonite
