Old 09-27-2017, 10:54 AM   #1
Heater63
Heater63's Avatar
Short Fenders too??
Anyone else getting "short" repro fenders?? I am finding that repro front fenders are about 3/8" shorter in length (fore to aft) than originals. This is causing an extreme fender to door gap that can't be adjusted out. My truck is original doors, inner fenders, the only repo part that could affect things is a repro core support. However, I have the original fenders, and they are longer than the reproduction ones.
I guess I will be welding a small extension to close the door gap. That is a lot of fine welding, but if Kindig can do it, so can I.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 09-27-2017, 11:15 AM   #2
VonDog
VonDog's Avatar
Re: Short Fenders too??
If your old ones are fixable, I'd use the originals.
60 K20, eaton HO52, T221, SM420, Dana 44 closed
78 K20 Burb, 14 bolt, NP205, SM465, Dana 44 open
05 Dodge Ram 2500 5.9 Cummins 4x4
VonDog is offline   Reply With Quote
Old 09-27-2017, 12:03 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Use steel rod to build up the lip on either part. Its solid enough to weld to without burning, and you can keep the nice "roll" on the edge without filler.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-27-2017, 01:59 PM   #4
Brad54
Brad54's Avatar
A lot of times, guys will use all of a reproduction panel, because they feel like they need to get their money's worth out of it. I've seen guys hang full quarters on a car, when all it needed was the bottom area in front of and behind the wheel opening, and parts of the wheel lip.
Other guys bought the full quarter, and then just used the pieces they needed to fix their original. This preserves the original fit and contours, and is often a better solution.
You might think about using your reproduction fenders as donors to fix your originals. It's either that, or invest a lot of time and money in reworking the reproductions.
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 09-27-2017, 02:51 PM   #5
timmytimm3
I noticed my aftermarket rockers are longer than stock. I'm going to cut them even with the door and then the fender can be adjusted closer to the door (rearward).
Sorry no pics
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 09-27-2017, 10:56 PM   #6
rvrfoot
I got some i will put a tape measure on it saturday a see.Name:  DSCN0958.jpg
rvrfoot is offline   Reply With Quote
Old 09-27-2017, 11:27 PM   #7
rvrfoot
Old 09-29-2017, 12:32 PM   #8
Heater63
Heater63's Avatar
Sorry no pics
Not so fast, the front fender has to align in front with the front grill support. Where that is in space is determined by your inner fenders and thickness of the radiator support.
I would triple check rockers comparing to original before shortening them.
292 + TKO500
Old 09-29-2017, 12:38 PM   #9
Heater63
Heater63's Avatar
Originally Posted by rvrfoot View Post
I got some i will put a tape measure on it saturday a see.Attachment 1694118
Thanks Rvrfoot. Are you using an original or repop radiator support? I'm wondering if maybe my repop radiator support
is "thick" and moving the grill support and fenders too far forward. Hmm.
292 + TKO500
Old 09-29-2017, 03:02 PM   #10
rvrfoot
The radiator support is original
Old 10-06-2017, 12:05 PM   #11
timmytimm3
The doors are aligned with the cab and the rockers are longer (frontward) than the doors. I'm not running stock inner fenders and the grill support and radiator support are all aftermarket. If I don't push the fenders back to fit the door nice, the rear upper fender holes don't line up with the cab.
Question- Is your radiator/grill support vertical or leaning back?
timmytimm3 on IG
Old 10-09-2017, 12:38 AM   #12
Heater63
Heater63's Avatar
My radiator support is fairly vertical...the stock inner fenders have mating flanges that determine the geometry.
292 + TKO500
Old 10-09-2017, 12:47 AM   #13
Heater63
Heater63's Avatar
Update on my issue. My repop radiator support was "thick" with poorly finished bends and welds that held the grill support too far forward, and thus the fenders would not go aft enough. By massaging with a hammer, and moving the doors another 1/8" forward, I think the fender gap is acceptable now.
The front clip on these trucks "float" more than I like....any one poorly made or aligning part affects the whole front clip.
292 + TKO500
