Old 10-05-2017, 03:02 PM   #1
randy500
Tilt Column, $329 shipped
This is a van tilt that I converted to fit our trucks.
Completely disassembled, bead blasted and painted. Bearings cleaned and lubed.
Back up lights switch moved to proper lower column location and proper truck grommets and lower retainer installed.
Upper grommet and tilt lever are new reproductions.
Turn signal switch was disassembled, cleaned and lubed, no cracks in turn signal cam. Purple wire has a butt connector.
Shifter pin hole is a little loose, shifter arm spring tension seems to hold pin ok, I would epoxy the pin after install and that would fix it.
randy500 is offline   Reply With Quote
Old 10-05-2017, 03:03 PM   #2
randy500
Re: Tilt Column, $329 shipped
Another picture
Old 10-05-2017, 04:02 PM   #3
Coley
Coley's Avatar
If its a van tilt....is it the right length? or has it had the length changed to suit the pick-ups?
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 10-05-2017, 04:52 PM   #4
randy500
Coley
The center shaft stick out on this van tilt is about 2.5 inches more than a truck column which requires you to collapse your intermediate shaft, lots of threads on here how to get that done, most of those threads suck and are full of misinformation.
You can collapse the one you have or I can provide one ready to install for another $50.
Old 10-23-2017, 12:42 PM   #5
randy500
Had this sitting on my deck for a week or so, it’s pleasing to look at...who needs a nice column?
Old 10-27-2017, 10:57 AM   #6
randy500
ttt
Old 10-28-2017, 03:11 PM   #7
OL SKOOL
OL SKOOL's Avatar
Randy if i purchased this whats the chances you could paint it victory red. How much extra to paint it Thanks Bob
OL SKOOL is offline   Reply With Quote
Old 10-28-2017, 03:20 PM   #8
randy500
I can’t paint it.
Old 11-01-2017, 11:58 AM   #9
randy500
Ttt
Old 11-05-2017, 11:15 AM   #10
randy500
Ttt
Old 11-05-2017, 11:53 AM   #11
04ls1gto
So is this ready to bolt in to my 71 burb or would it need to be modified?
04ls1gto is offline   Reply With Quote
Old 11-05-2017, 12:07 PM   #12
randy500
Read post 4, needs intermediate shaft collapsed, column is ready to bolt in
