11-15-2017, 11:57 PM | #1 |
Adding cab trim
Anyone gone through the trouble in adding the cab trim for the two tone white top look?
11-16-2017, 09:35 AM | #2 |
Re: Adding cab trim
I just use screws for the molding hangers...
Jimmy Hoelzel |
11-16-2017, 08:53 PM | #3 |
Who Changed This?
Re: Adding cab trim
Yeah, I don't think you'd want to duplicate the spot welded posts. Just be sure to put sealer on the screws when you put them in.
11-16-2017, 09:27 PM | #4 |
Re: Adding cab trim
When I started in the body shop biz back in 1980 there were still a lot of 60's and 70's GM cars and trucks coming through the shop.When we bought replacement trim from GM they would come with the nylon retaining clips and some tiny #1 Phillips screws that had a shoulder that would hold the clips without over tightening them. You could even snap the retaining clip on and off after installation just like the welded studs. It would be great to find a supplier of those now.Made installation a snap.
11-16-2017, 10:47 PM | #5 | |
Re: Adding cab trim
https://www.classicindustries.com/pr...s/4492963.html |
11-17-2017, 08:02 AM | #6 |
Re: Adding cab trim
You can also use the stud gun (dent puller) to weld the retaining tabs on.
http://www.eastwood.com/stud-welder-trim-rivet-tip.html
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 11-17-2017 at 08:07 AM. Reason: Added link |
11-17-2017, 08:35 AM | #7 |
Re: Adding cab trim
That would be them!
11-17-2017, 09:27 PM | #8 |
Re: Adding cab trim
I saw/read that someone would use plastidip on the screw threads before screwing into the sheet metal for trim to prevent rust.
