Old 11-29-2017, 01:48 PM   #1
BurbFam
15x12 on 3/4 ton
Hello all, new member here. I remember seeing a wheel/rim fitment thread on here, or maybe another site? Either way, I’ve recently picked up a 1991 3/4 ton suburban 4x4. It’s got i believe 3” fender flares but stock wheels. Looks dumb how sunken the wheels look. I found some 15x12s with 3” of backspacing, according to the seller for $80. 1) how far will these tires stick out and 2) is that enough backspacing to clear the calipers? Thanks all and look forward to get to know you guys and help as much as i can!
BurbFam is offline   Reply With Quote
Old 11-29-2017, 02:25 PM   #2
SCOTI
SCOTI's Avatar
Re: 15x12 on 3/4 ton
15x8" 6-lug truck ralleys are common for 4x4's. They have 4" of back spacing & clear calipers so the 3" will clear.
The 12" width & 3"BS will extend about 5" from the edge of the fender lip. More than likely that is beyond most common flares. You can determine the 'will they work' on your own. Pull a wheel & verify the back spacing. Hang a plumb bob off the flare & measure the current distance from it to the current wheel/tire combo. Then it's simple math for your answer.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 11-29-2017, 02:29 PM   #3
BurbFam
Mine is 3/4 Ton so it’s 8 lug. 3/4 Ton calipers are bigger than halfton right?
Old 11-29-2017, 03:38 PM   #4
DieselSJ
15" might not fit over the calipers.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 11-29-2017, 05:00 PM   #5
SCOTI
SCOTI's Avatar
Whoops.... Overlooked the 3/4 ton 8-lug portion. I would bet 16's are needed as well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-30-2017, 08:01 AM   #6
cadillac_al
Back in the day guys had to shave the calipers a little to get 15" wheels to fit on a 3/4 ton. I contemplated it for a while to get lower tires for truck pulling. I would keep looking for a more normal size wheel. I like 16x10's with 12.50 tires.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 12-03-2017, 09:49 PM   #7
bmchevy1979
bmchevy1979's Avatar
I run 15x10 with a 4in backspacing on my 3/4ton swapped k5 I did have to grind the caliper bracket and smooth the caliper a little bit not much I'd say that the 3in backspacing would clear without any grinding. These are the only good pics i have of them on my rig at the moment.
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 12-04-2017, 02:51 PM   #8
BurbFam
Right on. Thanks for help, i ended up finding a set of 16x10 eagle alloys with 315/75 BFG all terrains for $100. Now onto a lift, 6” is what i need to run 35’s correct? With no rubbing and no fender cutting?
