Old 01-05-2018, 03:52 PM   #1
kx57
'72 GMC Manual Trans Mounts
Hi,
I've just spent about an hour googling and going through old threads. Can't find a picture or diagram. Hoping someone can post.
I am re-installing my OEM 4 speed SM465 on a factory Manual transmission crossmember.
Does anyone have pictures/diagrams of how the mounts looked from the factory when installed?
The uninstalled mounts look like this:
https://www.summitracing.com/int/parts/ani-2107
https://www.summitracing.com/int/parts/ani-2108
I can find a thousand threads with aftermarket (different) mounts or people swapping in other transmissions...not seeing any pictures in any SM465 threads that show the mounts *installed*.
Thanks.
kx57 is offline   Reply With Quote
Old 01-05-2018, 04:29 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: '72 GMC Manual Trans Mounts
This is the best I can do for now. The smaller rectangular biscuit goes underneath. Does the truck still have the original engine in it?
Generally if someone has put an automatic trans in place of the manual they will remove this cross member.....
LockDoc
Leon
Old 01-05-2018, 04:32 PM   #3
kx57
It is a replacement 350 but it had a 350 in it originally.
I would love a picture from underneath and one of the mount without the bellhousing there if anyone has one.
I assume the "biscuit goes underneath and you bolt right through into the bellhousing?
Old 01-05-2018, 04:42 PM   #4
LockDoc
LockDoc's Avatar
It is pretty straight forward. You will see how the small rectangular biscuit fits when you put it up in the bottom. Yes, the bolt goes through the biscuit, through the cross member, through the upper mount and into the bell housing. There is a metal sleeve that fits into the biscuit and slides up into the upper mount. It is about 9/16" in diameter and 1 3/4 - 2" long.
LockDoc
Leon
Old 01-05-2018, 04:55 PM   #5
kx57
Okay thanks. When I get it together I may try and grab pictures and post it so it's available for others.
Old 01-05-2018, 05:22 PM   #6
LockDoc
LockDoc's Avatar
Good deal.
LockDoc
Leon
