4x4 thought
What if you had a long bed 2wd with coil spring rear, added another set of trailing arms and coil springs to the front and added a front 4wd axle? Lots of work, but cool idea.
But not as wacky as that one where it has two driveshafts and diffs on the front!
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Re: 4x4 thought
You mean basically flip the rear suspension design around with a steering axle? I think it would have very undesirable handling at best, and at worst be dangerous to drive at speed. I think the trailng arm suspension is only suitable to be just that - trailing.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
![]() Join Date: Oct 2015
Re: 4x4 thought
Ford did it for years with wishbones and then radius rods.
