Old 02-15-2018, 09:12 PM   #1
dusterbd13
Steering box options
Picked up a 95 regular cab stepside sport model 2wd.
Hate the steering feel.
Loved the jeep grand Cherokee steering box in the chevelle. Felt perfect.
Anyone found a similar junkyard swap for these trucks? Or maybe the jgc box swaps in?
Ive been searching and only come up with the 454ss box.
dusterbd13 is offline   Reply With Quote
Old 02-16-2018, 01:29 PM   #2
Tom
driving is in my blood
Tom's Avatar
Re: Steering box options
Been searching for years for something new for my 98. They ain't out there. Everything is just re-sealed, maybe re-valved, but still original gears and slop as they don't make replacements. You just order new ones and keep swapping until you find one you like. sucks.
Old 02-16-2018, 02:30 PM   #3
KeithT712
KeithT712's Avatar
I've got a 95 suburban 4wd, I run an AGR box on it and even with 35s I've always been happy with the feel. Granted a 2wd sport truck and a lifted suburban are two very different vehicles still just my .02 / aftermarket steering box experience so far
KeithT712 is offline   Reply With Quote
Old 02-16-2018, 10:18 PM   #4
Zook75
Zook75's Avatar
Have y'all looked into the Red top box? they do more then just replace the parts, they add bearings and other things to tighten them up.. I got a 91 4wd Jimmy i'm going to check into getting one for.
Zook75 is offline   Reply With Quote
Old 02-16-2018, 11:15 PM   #5
KeithT712
KeithT712's Avatar
Red head steering? i hadn't heard of them before but its good to know of another company, like i said I've got the agr in my 95 with no complaints but also just installed a psc box in my 90 suburban build so i'll see how that one works out too
1995 GMC K1500 Suburban 6" Pro comp 35x12.50R17
LSXburb -Build- 1990 GMC Suburban 6.0 Lq4 4l80e np205 D60 14FF
1988 GMC suburban 350ci Sm465 D60 14FF 8" 39.5x15R15
1969 Pontiac Lemans 400ci Muncie 4 speed
2009 Pontiac G8 Gxp M6
Old 02-17-2018, 05:10 PM   #6
Kudzupatch
Kudzupatch's Avatar
From what I understand our trucks use a Saginaw 800 steering box and lots of cars used those. The most common fast ratio is 96-98 Grand Cherokee. Have not done this yet, but I have to replace some tie rods in the next couple of weeks and I want to swap the steering box at the same time.
PS. Doing a little research I found that you can buy a GM rebuilt unit with lifetime warranty from Scogging Dicky as well as other places. ACDelco 19321370
https://sdparts.com/i-24095698-acdel...4aAg7_EALw_wcB
Kudzupatch is offline   Reply With Quote
Old 02-17-2018, 05:30 PM   #7
dusterbd13
I'm inclined to believe you are correct that it is an 800 series box. I'm inclined to believe you were correct that it is an 800 series box did a lot of poking around at it today and it appears to be one. Additionally the Jeep Cherokee steering shaft swap that is common on the S10 with the 800 series box works for the C 1500 as well. Eyeball in the steering shaft from the output from the box it appears to be the same threads and diameter as the Jeep Grand Cherokee box. Depending on whether I may go grab one from the junkyard and try it. Truck needs Pitman and idler arms anyway and it would be the perfect time to do it.
Old 02-17-2018, 08:33 PM   #8
Zook75
Zook75's Avatar
yes it was Red Head not top. I hear they are the real deal to fix our issues. If i can drop $400+ for a radio, I can surely pay $300 for a part that makes driving a short Blazer safer.
https://www.redheadsteeringgears.com/
Old 02-19-2018, 03:23 PM   #9
Tom
Tom's Avatar
Cherokee swap doesn't work with 96+ trucks, steering column is different.
Old 08-29-2018, 04:05 PM   #10
Kudzupatch
Kudzupatch's Avatar
An update on this. The ACDelco 19321370 DOES NOT fit the Suburban contrary to everything I have read. The casting is a #27 and the Suburban has a a casting number of 83. Same box, everything's the same except one of the mounting holes will not line up. Not sure but it is my impression that the trucks use the same box.
Totally ticked off too. I should have to caught but that of course I didn't till I put it in place. Now mine is torn apart and I have to order a new box. I gave it just ordered one from RedHead. At this point I don't care about the cost, I just want my truck back.
Old 09-03-2018, 07:02 AM   #11
I always felt these trucks had a nice feel to the steering. What issues are people talking about, worn out boxes?
Old 09-03-2018, 11:45 AM   #12
Kudzupatch
Kudzupatch's Avatar
Mine was worn and leaking really badly. Plus I wanted faster steering.
Mine has been modified and for a Suburban handles really well, very flat cornering but it took a lot of steering input on tight corners. So I fixed both at the same time.
