Old member
I got 2 deep cycle 6 volt batteries. I wired them for 12 volts to run the winch on the ramp truck. I just installed them today so I'm charging them with my 12 volt charger.
My question is how would I wire them to the truck alternator so I can charge them while driving the truck? Also do you think the alternator would even charge them? What do I need to hook it up. I have plenty of cables and I have a blue sea switch that I can mount to turn it off from the system If I need to. Spec are 48 volts DC max @ 300amps. Shouldn't have any trouble with it. Right now I have 2 deep cycle 6 volts wired in series to = 12 volts. They are wired to the winch. If I put a small size cable from the alternator to the cutoff switch then to the + of the first 6 volt battery then ground the 2-6 volt battery to the chassis, that's all I need right? ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Ramp truck winch??????????
Your thinking sounds correct to me. We have an old international backhoe that was 12 volt but originally used 2 6s. We did a one wire alt conversion and just ran that wire to the + of the final battery
Old member
I think instead of the manual cutoff switch I'll use one of my old golf cart contactor's and have it where I can turn it on/off from inside the truck whenever I need to.
It's good for 400amps which should be plenty. ![]()
I used a battery isolater When I wired my camper 12v deep cycle battery. It look like a ford starter solenoid, but is rated for contentious duty, seems like it was around $30, and allowed me to separate the batteries when I was camping so I didn't run the truck batteries down. You can wire them where 12v hot from ignition turns them on,or do like I did, and put a lighted switch on the dash (so its harder to screw up and leave them on.)
I've watched your builds with intrerest, Hi from upstate sc, I'm near Chesnee (northeast of Spartanburg) |
#5 | |
Old member
![]() Quote:
I may have to replace the alternator also to handle the amps???? Have you joined our Face Book club yet? You need to man we have a good bunch of people locally. ![]()
I have a radical idea!
I wired the rear battery in series with the battery in front in Brutus and used a 105 amp alternator from a mid 80's IROC and never had a problem. I just it them charge both batteries all the time. I never had a problem with that setup for 10+ years hauling 100's of cars (lots of them with no wheels and tires) in that time. I did use 2 800 CCA batteries. My truck has rear side boxes, so I mounted one in the box right under the winch.
I always pulled cars up on the truck with the engine running.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#7 | |
Old member
![]() Quote:
Thanks this is the kind of info I was looking for. If I connect a cable between the truck battery and both 6 volt deep batteries with the contactor I pictured I can charge them whenever I need to. I shouldn't need a wire ran from the alternator to the extra batteries they should charge through the truck battery. I can turn the charging off also by flipping the dash mounted switch. ![]()
#8 | |
The 383 in my truck was pushing the limits of a pump gas iron headed engine, and it would drag the starter just a little on hot 95+ Degree southern summer days before I put the extra battery in. Never happened again after that. It could help guys with cold weather starting up north too, I'd think.
Old member
Good deal. The drivers side valve cover took on some damage while getting the manifold off so I took both covers off and will get new gaskets for them and reinstall. I straighted out the flange are best I could. I'll buy some good rubber gaskets for them and RTV them in good.
You can see they have been leaking for awhile! ![]()
![]() Join Date: May 2012
I would just get some 0 or 00 and run the cable to the front battery, with one size larger grounded back to the battery. If I had an isolated deep cycle aux battery, I would still power the winch from the starting battery. The winch likes the CCA. If you winch a lot get two decent batteries with the cold cranking amps in mind. Winches like juice, and the startup bump can be a heavy amp load. It's why you want your cutoff to be something with a working rating of say 300 amps but a surge rating or 1000+. If I have a cutoff, I like it near the winch clutch. I've never used a deep cycle for a winch, and I've never isolated the winching battery from my starting battery. But there's lots of opinions on that for sure. I just like simple, because it's simpler!
![]() j
White K20 |
#11 | |
Old member
![]() Quote:
#12 | |
![]() j
White K20 |
#13 | |
Old member
![]() Quote:
I have some cable I think some where. I'll look once it starts warming up and I get over this dang cold. I want it operational only if I need a emergency tow for one of the other toy's. ![]()
#14 | |
You should carry a come along too, just till you get a reliable setup. You can winch a foot then chalk, winch a foot then chalk. Or, take your son and make him push the stuff up there! ![]() j
White K20 |
#15 |
Depending on the size of the winch Warn recommends a battery with at least 650 cases. Do you kno the cra of your 6 volt batteries? You would add the two together to get the total. Make sure to run both winch battery cables to the battery terminals. Don't run the ground cable to the frame. Try to mount the batteries as close to the winch as possible to avoid voltage drop through the cable length too.
#16 | |
Old member
![]() Quote:
Why do you need to run the ground back to the truck battery? Just curious?Yes the 2-6 volts are right beside the winch with no more cable than needed. ![]()
#17 | |
![]() j
White K20 |
#18 |
Old member
Well I decided to move the 2-6 volts to the passenger side of the bed. This will make for a shorter run to the truck battery. shorter is better!
Well in this case! ![]()
