Old 03-25-2018, 12:11 AM   #1
focusedontheprize
focusedontheprize's Avatar
Late 1949 - 1953 Chevy Rear Cab Mount Measurements
So it looks like I lost my rear cab mounts in the shuffle of our move (no idea how it happened). I wanted to build a set of rear solid mounts anyways.
Would anyone be able to take some measurements off of theirs for me? Looking to know:
- How high they sit above the top of the frame rail
- Distance from the outer end of the frame rail to center line of the closet hole
Thanks.
focusedontheprize is offline   Reply With Quote
Old 03-25-2018, 01:39 AM   #2
MARTINSR
MARTINSR's Avatar
Re: Late 1949 - 1953 Chevy Rear Cab Mount Measurements
I can do this easy tomorrow but what exactly do you have? Do you have any of the mounts? The part that is mounted to the side of the frame and then the other part on the cab look like the end of a leaf spring. The piece in the center looks like a shackle. What are you missing?
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 03-26-2018, 04:30 PM   #3
focusedontheprize
Thanks MARTINSR. I only have the front cab mounts - I am missing the complete assembly for the rear cab mounts (shackles and mounts to frame and cab).
I am planning on cutting a set of new ones to make them solid mounting points for the frame. The measurements I am looking for is:
- Width of the mount that bolts to the cab
- Length of mount that bolts to the cab
- Height of mount (that bolts to the cab) to top of frame rail.
- Distance of center line of farthest hole to outside edge of the frame.
Thanks again for this MARTINSR. Hopefully it makes sense.
Old 03-26-2018, 04:34 PM   #4
MARTINSR
MARTINSR's Avatar
I have to tell you, I don't think these numbers are going to do any good for you. You may have it in your head but it depends how accurate I measure! And where, center to center, full length, that sort of thing.
I can take photos and do it so you can copy what is there, but it sounds like you plan on making them a little different. So if that is the case just knowing the distance from the frame to the bottom of the cab is all you need.
I will make the measurements you ask for but honestly, I don't see how you can use them if you are changing how they work anyway.
Brian
1948 Chevy pickup
Old 03-26-2018, 04:35 PM   #5
MARTINSR
MARTINSR's Avatar
Please elaborate on the last one, "Distance of center line of farthest hole to outside edge of the frame."
Brian
1948 Chevy pickup
Old 03-30-2018, 12:54 AM   #6
MARTINSR
MARTINSR's Avatar
I'm sorry, I forgot to do this for you. I will get it tomorrow night.
Brian
1948 Chevy pickup
Old 03-30-2018, 12:55 AM   #7
MARTINSR
MARTINSR's Avatar
But what was is it you need on the "Distance of center line of farthest hole to outside edge of the frame."?
Brian
1948 Chevy pickup
Old 03-31-2018, 12:41 AM   #8
MARTINSR
MARTINSR's Avatar
Ok, I am reading your requests and see that those aren't the measurements I got! Geez, I can get them tomorrow but here are these.
First, the length of the mount that bolts to the cab, the one on the frame is the same by the way, the only difference between the two mounts are the placement of the bolts that attach it. The overall length is 3 5/8". The length from the edge to the center of the bushing hole is 2 7/8"
The distance from the cab to the top of the frame is 5/8"
The distance from the frame to the center of the bushing on the cab bracket is 3 7/8"
From the top of the frame to the center of the frame mount bushing is 2 1/8".
Brian
1948 Chevy pickup
Old 03-31-2018, 12:46 AM   #9
MARTINSR
MARTINSR's Avatar
The shackle length, center to center is 3 3/4"
Hope this helps, I will get the others tomorrow that I missed.
Brian
1948 Chevy pickup
Old 03-31-2018, 11:01 AM   #10
mr48chev
mr48chev's Avatar
You are still going to have to have some sort of rubber cushion between the bracket and the cab.
My ongoing truck projects:
Old 03-31-2018, 12:23 PM   #11
MARTINSR
MARTINSR's Avatar
Why Mr48?
Brian
1948 Chevy pickup
Old 04-01-2018, 12:25 AM   #12
focusedontheprize
Thank you Brian, this is perfect!
Yeah Mr.48. I am playing on running a poly bushing.
