Old 03-26-2018, 11:59 AM   #1
Noah96
Gas Tank
Tightened the fuel line and sending unit up when it gets hot out and sun hits the cab it leaks on the fuel tank. When I take the gas cap off it lets off a lot of pressure how do I fix this problem. Would a new gas cap work?
Noah96 is offline   Reply With Quote
Old 03-26-2018, 11:45 PM   #2
cr1hotrod
cr1hotrod's Avatar
Re: Gas Tank
Seems like maybe the vent on your cap is not working. A new vented cap is the easiest thing to try. Hope it works.
1967 Longbed 4/6 static
2007 Silverado Z71 Crew
cr1hotrod is offline   Reply With Quote
Old 03-27-2018, 09:43 AM   #3
Noah96
Re: Gas Tank
Does anyone sell a vented gas cap looked on brothers and LMC didn't see any description saying if the gas cap was vented or not.
Old 03-27-2018, 09:57 AM   #4
s10mk
Re: Gas Tank
I just bought this cap from napa
https://www.napaonline.com/en/p/BK_7031220
Its meant for trucks without evaporative emision controls. Its vented, but only through a relief valve. I think that will be the case for most gas caps. So the tank will still build up some pressure, but the cap will relief at a preset pressure.
2009 GMC Sierra 1500
2006 Buick Lacrosse
1987 Chevrolet V10
1972 Chevrolet c20 350/350
1967 Chevrolet Biscayne ls3 swapped
s10mk is offline   Reply With Quote
Old 03-27-2018, 12:03 PM   #5
demian5
demian5's Avatar
Re: Gas Tank
71-72 cap is vented, 70 and earlier is not, its vented from the passenger upper corner of the tank, up the b-pillar and down and out of the floor of the truck. Its quite intriguing.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
