Factory cab lights and wiring
One lense was cracked in half and was glued together. The other four are very nice. All grommets look good. Mice got to the wires so some will need to be replaced. Includes the grommet from the kick board and all new stainless screws.
$75 shipped CONUS or reasonable offer.
1970 K10 1970 C30 1973 C30 1980 K20 |
Re: Factory cab lights and wiring
Where does it plug into? Fuse block?
Thanks Joe
Joe 1968 K20 1970 K20 Semper Fi |
The hot wire plugs into the light switch and the ground was near the steering column.
On the light switch, was it molded into the wiring harness? Or is this something that can be added to any light switch plug?
Plugged into an opening in the light switch plug. I will get pictures when I get home.
The wire pictured went in the open opening at the upper right on the plug.
Someone asked about the numbers on the lenses. They are all the same as the one pictured.
The writing on the lenses is: SAE GUIDE 81A 69 PI
Hello, would you consider a offer of $50.00 for the cab lights? Thanks, Nick
I'll take them for $75. Thanks, Harlow
#10 | |
Joe
Ahh I see thank you
#13 |
Paypal sent. Thanks, Harlow
