Old 05-05-2018, 10:01 AM   #1
davepl
davepl's Avatar
Flaring hard line for AN
I want to go from hard 3/8 stainless line to AN, so I was going to use my hydraulic flaring tool with a 37-degree die.
I have the -6 tube nuts and rings...
Is it as simple as put the nut and ring on, single-flare it 37 and you're done? Seems too easy!
Any tips or tricks are welcome. I've done a lot of double-flare stuff but have never done a hardline AN flare ever!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-05-2018, 02:25 PM   #2
B. W.
B. W.'s Avatar
Re: Flaring hard line for AN
That's the way I've done it. Same as you, I've done lots of double flares but only a couple of AN.
B. W. is offline   Reply With Quote
Old 05-05-2018, 02:48 PM   #3
dell72
I have used an adapter that had a compression fitting on one side and -8 on the other.
dell72 is offline   Reply With Quote
Old 05-05-2018, 03:05 PM   #4
Steve Cole
That's it! Just make sure your ends are nice and square and de-blurred properly. Use some lube on your dies too.
Steve Cole is offline   Reply With Quote
Old 05-05-2018, 03:34 PM   #5
mike16
is AN 37 degrees? so SAE is 45 degrees or something like that?
mike16 is offline   Reply With Quote
Old 05-05-2018, 03:55 PM   #6
HO455
HO455's Avatar
AN is 37 1/2*. The link should help explain.
https://www.speedwaymotors.com/the-t...xplained/28780
RIP Bob Parks.
Old 05-05-2018, 10:20 PM   #7
mike16
37 1/2 degrees? AN is not SAE . big difference. any way good luck
Old 05-05-2018, 11:03 PM   #8
57taskforce
All about them K’s
57taskforce's Avatar
This... an and jic are basically the same just a different quality of fittings between the 2. Sae isn’t the same.
Tyler
57taskforce is online now   Reply With Quote
