Old 05-09-2018, 01:41 PM   #1
67chevemall
67chevemall's Avatar
Help with buying a clutch
Clutch is slipping more and more.
Time to get a new one.
How do I find out if I need a 10.5 ,11 or 12 inch ?
The ram hdx88760 and hdx88762 look like a good buy.
I have a 327 3speed to buy for.
Still not sure if it is saginaw or muncie
Any advice for a first time is welcome.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 05-09-2018, 05:18 PM   #2
BCOWANWHEELS
Re: Help with buying a clutch
get oriellys, there life time guaranteed. put back what comes out.....organic
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 05-09-2018, 09:22 PM   #3
RustyBucket
RustyBucket's Avatar
Guess your gonna have to disassemble it & look. Just ol' greasy nuts & bolts. Pretty straight forward, nice to have a lift & air tools. Done quite a few on the ground with hand tools. Might have to buy/borrow a pilot shaft tool to align the new disc & pressure plate & disc. Probably good youtube. Have fun !! ...... be a good idea to have the flywheel resurfaced..
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 05-09-2018, 10:40 PM   #4
BCOWANWHEELS
YOU don't have to pull tranny, just slide it back about 8 in. change pilot bushing and t/o bearing. alignment tool will come with kit. if clutch has been sliping a lot you probably need a flywheel too. cast iron is fine.
Old 05-09-2018, 10:43 PM   #5
BCOWANWHEELS
check / grease u-joints n hanger bearing
Old 05-10-2018, 09:54 AM   #6
67chevemall
Take it all apart and measure the clutch size or drop it off and swipe the visa.....humm
Old 05-11-2018, 10:56 AM   #7
67chevemall
Trying to find out what I have.
Been reading goggle for 2 hours now.
I think it is the m13 muncie but not sure.
It is cast with 7 bolts and has on the cover plate
M3 3868632
A my build sheet says m13 3 speed sync
Any ideas
Old 05-16-2018, 04:30 PM   #8
BCOWANWHEELS
std Saginaw or Muncie 3 speed, gm used both and there interchangeable
Old 05-17-2018, 10:18 PM   #9
mike16
you must remove the flywheel and resurface it. no "ought to" about it. if you dont it often does not last 10-15k more miles and it will not be covered by any warrenty
mike16 is offline   Reply With Quote
Old 05-18-2018, 08:10 AM   #10
67chevemall
Thanks again. It is definitely soaked in oil.
Not sure if I blew the main seal or my red neck oil
Spraying or both did it in.
Going to try 3 cans of brake cleaner before I tear it all apart.
