Old 06-08-2018, 09:14 AM   #1
Supergas
Supergas's Avatar
Talking New 1966 C20
Hi All,
Been away from this forum for a while doing other things, but I just picked up an all original 1966 C20 yesterday..
I am going to use it as a shop truck and try to keep it as original as possible while making it dependable enough for a daily driver.
Details: C20, 327, 4 Speed w/ Granny Gear & 4.11 gear. Running, driving truck, currently licensed and inspected. The truck is driveable right now, actually drove it yesterday down back roads and on interstate.., It revs pretty high at 70 due to rear gear but drives OK at 60.. Interior in good shape and no rust to speak of.
I would like to add power steering and power brakes as I am going to drive it frequently. My question is it it worth it to convert to Disc or just keep the Drum brakes?? It stops pretty good right now so was just thinking of going to power brakes and keeping the drums..
I really want to add power steering as I have a bum shoulder and although it steers OK for a 66, I would like to add a PS unit.
Any and all info would be appreciated.
Thanks,
Supergas
Gene
2021 Chevy Silverado CC Custom (DD)
2018 Tahoe LS
1964 Oldsmobile F85 Post
Supergas is offline   Reply With Quote
Old 06-08-2018, 09:26 AM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: New 1966 C20
Hey Supergas. Nice truck! Most people would say yes to the disc brakes, but I think drums are fine. One thing I would suggest for sure is going with a dual reservoir master cylinder. Good luck and have fun!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-08-2018, 09:52 AM   #3
Supergas
Supergas's Avatar
Re: New 1966 C20
Joseph,
I agree on the drum brakes.. I am going to retain them but add the factory or improved power booster, depending on recommendations.
First thing is to get the Power Steering installed..
Thanks for the feedback,
SG
Gene
2018 Tahoe LS
Old 06-08-2018, 10:18 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: New 1966 C20
Drum brakes are great if maintained properly, power drums are even better.
Power steering in this day is a nessesity
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-08-2018, 10:37 AM   #5
Supergas
Supergas's Avatar
Lightbulb Re: New 1966 C20
Clyde,
Yep, Power Drums are what I am going to do..
Anyone with a build on adding power brakes or part numbers that have been used with good results..??
I would prefer to use AC Delco parts or factory stuff and don't want chrome or anodized..
Gene
2018 Tahoe LS
Old 06-09-2018, 12:37 AM   #6
Captainfab
60-66 Nut
Re: New 1966 C20
I make both the steering box adapter plate and a booster bracket that allows you to use any of many many, compatible factory brake boosters. However if you are staying with 4 wheel drums, I recommend the '67-'70 booster and master assembly. Since your truck is a C20, I would go with the same C20 '67-'70 version.
Old 11-30-2021, 12:30 AM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: New 1966 C20
Any updates on this truck?
66 C20 Service Truck:
Old 11-30-2021, 01:49 PM   #8
Supergas
Supergas's Avatar
Re: New 1966 C20
This truck was sold/ traded for a 1964 Olds F85 Post, which has just been finished and is my current Hot Rod
Now looking for another similar truck but want
Supergas
Gene
2018 Tahoe LS
Old 11-30-2021, 09:30 PM   #9
66C10LB
Re: New 1966 C20
I agree that power brakes dual master with drums all around is a fine way to go.
66C10LB is offline   Reply With Quote
