Old 06-15-2018, 09:31 PM   #1
72Mountaineer
72Mountaineer's Avatar
Door panel hump
New door latches, and I put the new cardboard door panels on my '53, and they've got this nice hump in them where the door latch rod connects and sticks way out. The latches are new and correct, is this a normal condition?
72Mountaineer is offline   Reply With Quote
Old 06-15-2018, 11:12 PM   #2
MARTINSR
MARTINSR's Avatar
Re: Door panel hump
You know what's weird, the AD inside door handle actuators are wrong on these trucks. The piece that goes between the handle and the latch goes at an angle and not in the recessed area that was designed into the door!.
And over and over you will see modified trucks with this mistake still!
Back years ago with my original doors I modified the linkage to run properly in the recessed area on the door!
I will be doing the same on the doors I am running now, I don't get it, I don't have a clue why Chevy made them like that, it makes no sense to me!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 06-16-2018, 12:54 AM   #3
mr48chev
mr48chev's Avatar
Re: Door panel hump
I actually went out and looked a door I have to make sure that rod did go that way. This one is bent because the door was jammed closed. Who ever drove it would slam their shoulder against the door to open it until they bent the door and window molding.
My helper was waiting for me to get done taking photos.
My ongoing truck projects:
Old 06-16-2018, 12:58 AM   #4
MARTINSR
MARTINSR's Avatar
Re: Door panel hump
I like your kitty!
Brian
1948 Chevy pickup
Old 06-16-2018, 01:07 AM   #5
MiraclePieCo
MiraclePieCo's Avatar
Re: Door panel hump
Two ways to avoid the door card hump:
1) Locate some OEM '47 relays (which ran inside the door recess), or
2) Do what I did: use mid-60's relays.
They also run horizontally in the door recess, but require minor modification to install (note the welds where I had to shorten the arm slightly):
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 06-16-2018, 10:23 AM   #6
MARTINSR
MARTINSR's Avatar
Re: Door panel hump
RIGHT ON! I need to remember this!
Back when I did my truck in the late seventies I pulled apart the original relay and reassembled it upside down as I remember. I am pretty certain I remember grinding the tabs off so the outer piece would come off and then plug welding it back on, but your way makes more sense.
Brian
1948 Chevy pickup
Old 06-16-2018, 02:47 PM   #7
MiraclePieCo
Re: Door panel hump
Brian
64-66 Chevy/GMC PU
You'll need to cut and reweld the arm and enlarge the mounting holes slightly. 10-minute job, so it should take you two days
Old 06-16-2018, 03:25 PM   #8
MARTINSR
MARTINSR's Avatar
Re: Door panel hump
64-66 Chevy/GMC PU
LOLOLOLOLOLOL
Brian
1948 Chevy pickup
Old 06-18-2018, 02:23 AM   #9
Matt_50
Re: Door panel hump
I'm saving this for later.
Martinsr, flipping them did or didn't work?
1950 Build
Matt_50 is offline   Reply With Quote
Old 06-18-2018, 03:07 AM   #10
MiraclePieCo
Re: Door panel hump
Here's the original service manual photo for the '47-'48 trucks, showing the early style door relays running horizontally inside the door recess. Not sure why Chevy changed it.
Old 06-18-2018, 10:08 AM   #11
MARTINSR
MARTINSR's Avatar
Re: Door panel hump
As I remember I had to pull them apart and rotate them and weld them back together. I don't have one that isn't in a box in the attic so I can't pull it out and take a look right now.
Brian
1948 Chevy pickup
Old 06-18-2018, 11:52 AM   #12
b-mac
b-mac's Avatar
Re: Door panel hump
If memory serves me correctly, I think the Altman kit has you flip the door handle, or change side to side. I'm pretty sure it used the correct guide path. The Altman site instructions aren't that great, but a couple of guys on this site have done great write-ups.
b-mac is offline   Reply With Quote
Old 06-18-2018, 12:10 PM   #13
b-mac
b-mac's Avatar
Re: Door panel hump
I am mistaken...
