Old 06-25-2018, 05:44 PM   #1
pjr
Is this really the original hood?
Saw this 1984 C20 in an ad, lister says it's "original two-tone paint" but I don't remember ever seeing a hood that didn't match the top of the side panels… but it does also seem to match the top/back of cab and the lower panel color… was there ever a two-tone option like this?
I only knew this options shown in this post: http://67-72chevytrucks.com/vboard/s...87&postcount=6
I was sure at first this was a replacement hood, but the more I looked the less sure I was, so I thought I'd check with the pros…
Ad with more pictures is here: https://portland.craigslist.org/clk/...624535618.html
pjr is offline   Reply With Quote
Old 06-25-2018, 06:26 PM   #2
Bandit130
Bandit130's Avatar
Re: Is this really the original hood?
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is online now   Reply With Quote
Old 06-25-2018, 06:58 PM   #3
pjr
Thanks Bandit130!
Here's one example of a special edition from '78 with a non-matching hood, but that's the only thing like this I've found so far…
https://autowise.com/wp-content/uplo...beau-james.jpg
Old 06-25-2018, 07:27 PM   #4
mongocanfly
mongocanfly's Avatar
welcome....
if the spid is still there it should show it
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-25-2018, 09:13 PM   #5
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: Is this really the original hood?
Keith Seymore probably know the answer to this. Maybe he'll chime in.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 06-26-2018, 07:13 AM   #6
Keith Seymore
Keith Seymore's Avatar
Not from the factory that way.
The hood and cowl panel are the primary body color in all of the two tones in your attachment.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-29-2018, 04:30 PM   #7
LT7A
Could it originally have had the sport stripes that were removed? It seems like I've seen those with a secondary color on the hood.
Old 06-29-2018, 05:49 PM   #8
kwmech
Still worth 1500.00 even with all the AC stuff missing
Old 07-02-2018, 04:14 PM   #9
pjr
Thanks for the info everyone.
Old 07-04-2018, 12:05 AM   #10
Pontiac1976
Pontiac1976's Avatar
When you open the hood look @ the reinforcement on the aftermarket hoods you see that the reinforcement is much thinner then factory (and lighter)
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
