Old 06-28-2018, 06:09 PM   #1
jkk
jkk's Avatar
Sound deadening materials
Hey Guys
Looking at sound deadening materials which do you recommend?
Can you really tell a difference my truck has no headliner so will not be doing that just the floor and possibly the inside of the doors if that would help
Average cost?
Thanks for any info
jkk is offline   Reply With Quote
Old 06-29-2018, 07:00 AM   #2
70GMCer
70GMCer's Avatar
Re: Sound deadening materials
IMO....you can go with the "High Priced Spread" like "Dynomat" or do like I've done on many of my projects & use https://www.amazon.com/Frost-King-FV.../dp/B00H26CPFS on the cheap....
Can also be bought at Lowes, Home Depot etc.
Maybe not as good as the higher priced ones, but it has always quieted down my vehicles....
Added is a pic I just did on my 83
I'm sure others will respond
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-29-2018, 12:25 PM   #3
HunterRotten
HunterRotten's Avatar
I got a generic ebay brand and made sure that the material was butyl instead of asphalt. The brand I used is called GT Mat and it was their 70 mil thickness I believe. Pretty easy to install. I cleaned up all my edges using 3M foil tape.
My cab is not completely sealed up as of yet, I have a hole in the firewall open to the cab and no shift boot but I can tell a massive difference from before. I topped it with a vinyl mat.
HunterRotten is offline   Reply With Quote
Old 06-29-2018, 03:30 PM   #4
rideair
I would look and read the information on this website.
https://www.sounddeadenershowdown.com/
Though I did not purchase product from them, I did follow their thought process of the CLD Tiles, Mass Loaded Vinyl and Sound Absorber.
Instead of using "Hydrophobic Melamine Foam (HMF)" as the sound absorber, I decided to use the 3M Thinsulate SM600L/SM400L (cost a little more money) and is a better product IMHO.
rideair is offline   Reply With Quote
Old 06-29-2018, 03:45 PM   #5
Akuzaspur
Here’s one I used, worked great and priced right.
https://www.amazon.com/Noico-deadeni.../dp/B01KZ5X7KO
Originally Posted by jkk View Post
Hey Guys
Average cost?
Thanks for any info
Akuzaspur is offline   Reply With Quote
Old 06-29-2018, 09:39 PM   #6
epfatboy
I have used either lowes or home depot sealer and noticed a huge difference in the cars I have done in the past.
I was going to post a similar thread but since this is going....
How much more difference in sound deadening does adding Door carpet or a headliner? I plan to carpet up the back of the cab as well as I assume every little bit helps... right?
epfatboy is offline   Reply With Quote
Old 06-29-2018, 10:11 PM   #7
rideair
I used the same product as Akuzaspur,
"Noico 80 mil car Sound deadening mat, butyl automotive Sound Deadener, audio Noise Insulation and dampening".
I would suggest getting the metal roller for install. The product was installed throughout my 1988 Suburban, then placed Mass Loaded Vinyl over top, Jute padding, then Mass-Backed carpet to finish it off. Yeah, I know a little over kill, but the Suburban road noise and heat have been greatly reduced.
In the doors, Noico (inner/outer metal), Mass loaded vinyl and SM600L behind door panels. In the ceiling, it got Noico and SM400L under the headliner.
Old 07-04-2018, 08:34 AM   #8
44th Miss Inf
What’s a rough idea of how many square feet of material does it take to cover a high hump floor? Back wall?
44th Miss Inf is offline   Reply With Quote
Old 07-04-2018, 08:44 AM   #9
HunterRotten
I bought 60 sq ft of gtmat 'onyx' which is a butyl material and is 70 mil. I got 25 12x24 sheets and 10 12x12 sheets. I have about 5(?) 12x24 sheets left. I did the inside of the firewall, floor, and back wall of the cab on a low hump truck.
Old 07-04-2018, 11:29 AM   #10
4x4chase
Am I the only one going to give Lizard Skin a try?
4x4chase is offline   Reply With Quote
Old 07-05-2018, 10:53 AM   #11
Wgesnerjr
Wgesnerjr's Avatar
I used Lizard Skin system. Temp Control on the outside firewall, underside of the floor and the underside of the bed. Then used the Sound Control on the inside firewall, inside floor boards and back wall. I have not driven (except around the block) and it does not have any resemblance of exhaust yet. So I cannot testify to how well it functions because EVERYTHING IS LOUD!! LIKE NASCAR LOUD!!
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 07-05-2018, 11:32 AM   #12
RADustin
used lizard skin on a few builds. never performed well.
1949 Chevy 3100 P/U
http://67-72chevytrucks.com/vboard/s...d.php?t=302780
1976 GMC Sierra Classic C35 CCSB
http://67-72chevytrucks.com/vboard/s...25#post8188825
RADustin is offline   Reply With Quote
