Old 07-14-2018, 12:38 PM   #1
70GMCer
70GMCer's Avatar
AC Almost Completed
Installed new condenser, evap, dryer/accumulator, Orifice tube & compressor.
Now, just waiting for the hoses to come in.
Hope it works....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 07-14-2018, 03:08 PM   #2
Re: AC Almost Completed
Looking good
Old 07-17-2018, 02:14 PM   #3
70GMCer
70GMCer's Avatar
Another step closer.
I made up the hoses. Now, I just have to find a place in my area to crimp the ends..
1997 GMC Sierra Ext
1965 Mustang
Old 07-18-2018, 09:46 AM   #4
jwilson645
For those of us who are about to tackle this same chore, can you list what parts you used and where you purchased?
jwilson645 is offline   Reply With Quote
Old 07-18-2018, 11:17 AM   #5
70GMCer
70GMCer's Avatar
ok....here's what I bought with part numbers.
RockAuto Condenser SPECTRA PREMIUM 73642
Evap FOUR SEASONS 54275
Drier/Accum FOUR SEASONS 33204
Amazon Orifice Tube Four Seasons 38635
Ebay Compressor Sanden 508 V-Belt
Hose Kit https://www.ebay.com/itm/Universal-1...72.m2749.l2649
AC Drier fitting https://www.ebay.com/itm/NEW-AC-FITT...72.m2749.l2649
Summit Vintage Air Bracket kit 15123-VCB
The costs for the hose crimping in my area is $25.00
The total cost to me is $474.61. Not counting MY labor or MY R134 Freon
Hope this helps others.
1997 GMC Sierra Ext
1965 Mustang
Old 07-18-2018, 05:50 PM   #6
DieselSJ
Nice. I completely rebuilt mine 2 years ago when I converted to R134. I wish I had swapped in a Sanden in place of the H6 though. What color orifice tube did you use? I went with blue based on input from the guys over at ackits.com.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 07-19-2018, 06:56 AM   #7
70GMCer
70GMCer's Avatar
I went with the red orifice due to being for r134 so this is a starting point. I liked the .61 orifice size.
I should have the system up & going within the next couple days.
I'll post how it works here...
1997 GMC Sierra Ext
1965 Mustang
Old 07-19-2018, 10:47 AM   #8
70GMCer
70GMCer's Avatar
Hoses connected & pulling a vacuum......hopefully no leaks.....
1997 GMC Sierra Ext
1965 Mustang
Old 07-19-2018, 11:55 AM   #9
70GMCer
70GMCer's Avatar
Vacuum system, charged with 2.75 lbs of R134
SUCCESS !!!! Working like a champ & blowing COLD !!!
So glad this is over with.....
1997 GMC Sierra Ext
1965 Mustang
Old 07-19-2018, 12:57 PM   #10
gmachinz
Now you just need a q-jet idle stop solenoid and bracket. The solenoid wire ties in with the light green wire on your 2-cavity male/female molded packard 56 connector located about in the middle up high on your firewall. That will kick up the idle about 200-300 RPM whenever the compressor engages since it will pull the motor RPMs down a bit with the AC on.
gmachinz is offline   Reply With Quote
Old 07-19-2018, 01:05 PM   #11
70GMCer
70GMCer's Avatar
That is the plan. I have my eye on a couple of them on ebay
1997 GMC Sierra Ext
1965 Mustang
Old 07-20-2018, 12:45 PM   #12
Jeepwm69
Have a link to the compressor you used? Looks like ebay has a ton of them.
Jeepwm69 is offline   Reply With Quote
Old 07-20-2018, 01:23 PM   #13
70GMCer
70GMCer's Avatar
Got one on the way
1997 GMC Sierra Ext
1965 Mustang
Old 07-20-2018, 03:11 PM   #14
jwilson645
Just picked up the evaporator(PART # :TEM 288017), accumulator (PART # :TEM 208533) and blue orifice tube (PART # :TEM 207316) at my local NAPA. They were about the same price as RockAuto after shipping.
Be aware that there are 2 different evaporators available for these trucks, one with a 90* tube and one with a 180* so look at your old one if you have one before you order.
Old 07-21-2018, 06:42 AM   #15
70GMCer
70GMCer's Avatar
Here's the ebay link https://www.ebay.com/itm/Sanden-508-...72.m2749.l2649
1997 GMC Sierra Ext
1965 Mustang
Old 07-23-2018, 01:14 PM   #16
Jeepwm69
Thanks.
My 83 has an R4 and I've been hesitant to replace it with another R4 given their reputation for short service life.
Think I might try the Sanden route
Old 07-24-2018, 07:35 AM   #17
70GMCer
70GMCer's Avatar
Thanks.
When I was doing research looking for ac parts, I did see where they make a conversion bracket kit for the R4 to Sanden 508 compressor.
I passed it up cause I didn't have any of the original brackets to use.
This is one place that sells that kit.
https://www.dirtydingo.com/shop/prod...oducts_id=1622
1997 GMC Sierra Ext
1965 Mustang
Old 07-24-2018, 03:54 PM   #18
Jeepwm69
Even better! Thanks for posting that!
Crud. Only works with serp belt systems.....
Old 07-29-2018, 04:34 PM   #19
70K10Hunter
70K10Hunter's Avatar
I will save this info. Thanks for posting.
BTW: were did you buy the A/C hose?
I think I would like to go this route on my 77 K25 because I don't like the boat anchor A6 compressor.
just now seen the hose kit.
70K10Hunter is offline   Reply With Quote
Old 07-29-2018, 04:44 PM   #20
70K10Hunter
Old 07-30-2018, 06:43 AM   #21
70GMCer
70GMCer's Avatar
I bought the hose kit on eBay https://www.ebay.com/itm/Universal-1...72.m2749.l2649
I also had to buy a #12 fitting on eBay to connect the hose to the drier/accumulator. The hose kit didn't come with the #12 fitting. https://www.ebay.com/itm/NEW-AC-FITT...72.m2749.l2649
I had the hoses crimped by a Hydraulic Hose Shop company near me. It cost me $25 to have the 4 fittings done.
1997 GMC Sierra Ext
1965 Mustang
Old 08-18-2018, 09:06 PM   #22
SunSoaked
SunSoaked's Avatar
Vintage Air install completed! Currently it's 106 and she's blowin cold at idle
SunSoaked is offline   Reply With Quote
