Old 07-17-2018, 08:55 AM   #1
Mains52
Has anyone made their own Rad Support for an AD?
I cut mine down to do the s10 swap scrapped what I cut out and then switched back to a stock frame. As I am getting closer to putting on my front sheet metal I was wondering if anyone had the dimensions or has made their own.
Mains52 is offline   Reply With Quote
Old 07-17-2018, 07:55 PM   #2
b-mac
b-mac's Avatar
Re: Has anyone made their own Rad Support for an AD?
Are you going back to a stock radiator? I could help you with the between-the-fenders part, but I cut the bottom off mine.
b-mac is offline   Reply With Quote
Old 07-17-2018, 10:12 PM   #3
rustycars63
Will be reworking my radiator support, going to make one out of three , my have some parts left over also.
rustycars63 is offline   Reply With Quote
Old 07-17-2018, 11:00 PM   #4
GreasyLikeaBurger
GreasyLikeaBurger's Avatar
I have my old one from my '52 off the truck sitting on the shelf. If you need measurements, let me know.
GreasyLikeaBurger is offline   Reply With Quote
Old 07-18-2018, 04:49 AM   #5
MiraclePieCo
MiraclePieCo's Avatar
Retailers sell a "street rod version" radiator support. It looks different than the original and mounts the radiator lower than stock. Should be easy to copy.
https://www.classicparts.com/1947-53...ctinfo/78-510/
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 07-18-2018, 07:40 AM   #6
Mains52
The plan is to use an after market radiator of ebay. I guess my main concern was with it being cut and not meeting up with the crossmember that I would have a bunch of work trying to keep my fenders in the right place. Maybe I am thinking to far into it.
Old 07-18-2018, 12:24 PM   #7
mr48chev
mr48chev's Avatar
I've got one laying out back actually several but some are GMC and big truck that I can get a pattern off.
If you are looking at a core support someone has the 3000 series trucks are 12 inches between the top and bottom bolt holes were the inner fenders bolt to the sides while the big truck cores are 13-3/4 + - a tad between those bolt holes.
My ongoing truck projects:
Old 07-19-2018, 07:35 AM   #8
Mains52
Thank you for that I guess I will just bolt it up and measure from there.
Old 07-19-2018, 01:31 PM   #9
mr48chev
mr48chev's Avatar
I got it dug out.
23 inches down the inside before the bend to the middle. I have one that has a gentle curved stamped piece at the bottom and one that is more of a 45 degree angle/
27-1/8 from the top to the bottom of the channel and then you add the pieces for the core support to bolt to the crossmember that stick down about 1/2 inch.
22-7/8 wide outside to outside.
Old 07-19-2018, 08:53 PM   #10
b-mac
b-mac's Avatar
Since the tolerances on these trucks are so loose, once you mount the inner and outer fenders and then grill, I would think you could mostly engineer the rest.
I would put a 2x4 on top of a jack, put the hood on, and lift the front enough so everything roughly lines up.
