Old 07-28-2018, 09:55 PM   #1
c10454
External trans cooler
Question for the guys that have a trans cooler in front of radiator, how did you route/run the lines thru the core support? My 76 does not have any existing holes that would work.
c10454 is offline   Reply With Quote
Old 07-28-2018, 10:21 PM   #2
100%Chevy
Re: External trans cooler
If you don't have a/c,there may be some holes already there in the boxed area next to the radiator on the pass side.
That's where I ran mine on my 82,C-30.
Or,possibly in the frame rail underneath the front of the radiator support,then up to the cooler.
Mike.
100%Chevy is offline   Reply With Quote
Old 07-30-2018, 10:19 AM   #3
SCOTI
SCOTI's Avatar
Mike.
This is how mine is done. My dually had a factory oil cooler plumbed this way so when I rebuilt the motor, I swapped in a new unit & also added another/duplicate set-up for the transmission.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-30-2018, 11:36 AM   #4
DieselSJ
Here is how I did my '87.
http://67-72chevytrucks.com/vboard/s...d.php?t=733459
Through the external cooler first, then through the radiator. Hot always fed into bottom with return at top.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 07-30-2018, 02:49 PM   #5
1957 Chief
Retired USAF
Like SCOTI said, I ran mine under the core support and up to the cooler.
Bubba
1957 Chief is offline   Reply With Quote
