Dominator D2500
Hello,
My airride install from hell is posing more problems. As a side note, this is self induced. I cupped my LCA's because it wasn't near low enough with the basic bag cups and plate kit. Anyway, I have dominator 2600s up front now and with an 8" pipe cup - they are a little too close for comfort. Anyone run 2500's and still think they ride OK? I have 2.5" drop spindles as well and I'm debating on going to the 2500's. Thanks! |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Dominator D2500
Most run 2600 up front due to engine weight.
2500 would be fine for the rear. I never understood how people that cup a-arms, know exactly where to "place the cup" in the lower arm,... unless you have the truck right there with you,... when you fab them.
Re: Dominator D2500
Yeah, that probably would have been ideal. LOL. However, there is such a large chunk that comes out of them that I would think its hard to really get them off too much? Larger diameter pipe would have been ideal in this case.
Re: Dominator D2500
I used switch suspension 2600 bags up front. the inside of my cups measures 7.625 I had to move the upper bag mount around and cycle the bag couple times but got the bag centered with about 1/8-3/16 around the bag when aired up or down. I wish I would of used larger cupped but they was cheap ($5.00) and easy to get.
1965 C10 long box laid out on bags ![]() instgram 65see_x .……………………….. ____ ..………________//__l \_____ ,,,,,,,/__(O)___//___/__(O)_/ |
#5 | |
Re: Dominator D2500
low n' slo
![]() Join Date: Mar 2009
Re: Dominator D2500
I know this is somewhat old, but the reason for cupping the arms is to get a few more inches of drop...or however tall those lower cups are.
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
| Bookmarks |
