Load C ride quality
I will be needing tires soon. If i reuse my rally rims, i'll either go with 31x10.5 or 265/75r15. Both around the same height. The 31x10.5 are Load C and discount tires says that will give me a ruff ride and I should go with the metric 265 with a softer sidewall for the street. The metric ones cost $10 more a tire. Discount right or just trying to up sell to a more expensive tire?
Re: Load C ride quality
Hey Bill, I ended up putting 31's on my 68 mainly to fill up the wheel well. I went with the Mastercraft Courser A/T with a C load and I am very happy with them, they ride very nice and they are quite on the highway. Hope this helps.
Aaron |
Its a truck I would use the load range c tires, I doubt you would notice the difference in ride.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
If your tires are bad right now, all you're going to notice is how nice it is to have good tires. For most of us, that's as close as we come to getting a 'new' truck
![]() I've always been stuck with E range tires, and never once have I been bouncing around in a 20-30 year old 4x4 and thought "I wish the tires didn't ride so harsh" lol. IMO if you use it in the rough, get as much sidewall meat as you can afford/tolerate. My IFS truck has BFG KM2s (I got an oddball size, don't do that, $$$) and I can't believe how quiet they are on the road. I've never had an offroad tire that was even close.
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually 1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr 1991 CR500 (95 Burb wouldn't stop catching fire )
The load C capacity is a Truck Trailer tire, for loading heavy loads. To be safe if you use your truck to carry loads.
If your driving your truck as a car and never carrying more then you and one person Only. Then SUV and light truck tires with B load rating would be smother ride. But the 4 tires still have to handle the weight of the truck your putting them on.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
| Bookmarks |
