Old 08-30-2018, 07:38 AM   #1
Tdrcreyn4
Tdrcreyn4's Avatar
Transmission Advice
I have a 1969 K20 with a 396, NP205, TH400. It has a 4" lift and I run 35's. It is not a garage queen and I use this truck and like the power and durability of what I have. I am now getting to a point where I want it more streetable without sacrificing the performance I have now. I was considering adding a gear vendors Over/Under Drive to the truck but now I am wondering if I might just be better off with a modern 4x4 transmission with overdrive. I want something that is tough and will stand up to off road but still allow me to take a long road trip without breaking the bank on fuel.
What advice do you have for me on this? I want something that can stand up to 450 - 500 HP and the torque requirements. What transmission/what do I need to convert over, etc. All opinions welcome and thanks in advance.
1968 C10 292/3 spd - sold
1969 K10 350/3 spd/205 - sold
1971 K5 350/4 spd/ 205 - sold
1970 K20 350/350/205 - sold
1969 K20 396/400/205 - work in process
Tdrcreyn4 is offline   Reply With Quote
Old 08-30-2018, 09:56 AM   #2
SunSoaked
SunSoaked's Avatar
Re: Transmission Advice
4l80e or nv4500.The gear vendors isn't cheap and your still left with a non-lockup transmission, although it would be the easiest to install.
Cheap-reliable-easy: you can pick two.
Decisions decisions.
SunSoaked is offline   Reply With Quote
Old 08-30-2018, 10:58 AM   #3
b454rat
4l80. Can be bought relatively cheap, and the controllers are cheaper now too. Plus not overly difficult to hook up to a 205.
Old 08-30-2018, 11:16 AM   #4
sweetk30
sweetk30's Avatar
4l80-e if you like auto . since you have a th400/205 your 205 should be 32 spline input . fairly easy to get adaptor for .
then look here for a great controler unit . www.usshift.com you want the quick 4 unit for the 4l80-e
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 08-30-2018, 07:01 PM   #5
Tdrcreyn4
Tdrcreyn4's Avatar
Thanks Guly!!! I like the auto. Will I still be able to run my stock speedo with this set up?
Old 08-30-2018, 09:08 PM   #6
sweetk30
sweetk30's Avatar
kind of depends on how you do it .
lots of guys do a 2wd 4l80 to use the speed sensors in the trans and keep the 205 cable drive .
others do the 4wd trans and modify the rear t-case output for vss sensor to let the controler shift correctly in 4w low .
some add in a cable signal transducer and piggy back the cable on that still .
www.offroaddesign.com offeres the vss sensor mod option if you go that route .
