Old 09-03-2018, 11:11 AM   #1
ooimpalaoo
ooimpalaoo's Avatar
89 suburban idle help
I have a 89 suburban it idles fine, then put it in reverse or drive and try and give it gas and it wants to stall out. what could this be? thanx for the help
ooimpalaoo is offline   Reply With Quote
Old 09-04-2018, 07:23 AM   #2
Re: 89 suburban idle help
Possible vacuum leak is my first thought.
Old 09-09-2018, 04:41 PM   #3
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I have the same problem on a 93 C1500. The fuel pressure is 12 lbs but dropped to 0 withen a second after fuel pump shut off. Ireplace the pressure regulator and the stumble is almost gone but still there a little. It'll be nice to see some ideas.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 09-10-2018, 04:34 PM   #4
mikebte
Could possibly be ignition related. If the ECM is not advancing the spark when fuel is applied you will receive a stumble, could also be temp sensor reading off causing the engine to think it is warmer or cooler than it really is.
Does the issue continue to happen once it is warmed up?
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
mikebte is offline   Reply With Quote
