Old 11-16-2003, 11:30 PM   #1
boataddict26
Question 2 piece timing chain covers????
Do they leak? I am thinking about getting one off ebay for 15.00. They are good because you dont have to drop the oil pan to get at the cam, but they seem like they would leak. Has any one had experence with these?
Mike
1978 Chevy C10 Currently under resto.
350 Getting face lift. .060, JEpistons, Modify heads. More will come with money.
boataddict26 is offline   Reply With Quote
Old 11-16-2003, 11:57 PM   #2
shavn80
I'm new here but I can answer your question...no they don't leak at all, they're great! the inner ring is bolted on with its own gasket, holding the pan seal in place, then the outside cover is bolted on with another gasket just like normal. 15 bucks is a steal...
shavn80 is offline   Reply With Quote
Old 11-17-2003, 12:03 AM   #3
boataddict26
Thanks shavn80. Just what I wanted to hear.
Old 11-17-2003, 12:04 AM   #4
1FaastC10
1FaastC10's Avatar
shavn, dont think that just because you're new here doesnt mean you cant answer questions. that's what we're all here for, to help each other out, and to share our love for GM trucks.
welcome to our addiction, you're gonna love it here.
Boataddict, didnt mean to hijack your thread, just saw a noob and figured i'd do the usual welcome.
1FaastC10 is offline   Reply With Quote
Old 11-17-2003, 12:11 AM   #5
shavn80
thanks Faast. I knew there had to be a kickass truck forum somewhere out there. I'm glad I found it.
Old 11-17-2003, 07:50 AM   #6
Mike76251
I tried a Mr. Gasket two-piece cover on this engine and it leaked badly right at the bottom.
There was nothing to hold the spacer ring to the outer cover at the bottom.
It appeared to be a design problem with no apparent fix.
Here is a shot with the two-piece cover on just before I rolled the engine over and found the massive leak,
Mike76251 is offline   Reply With Quote
Old 11-17-2003, 08:43 AM   #7
bigblock73
yeller
bigblock73's Avatar
Mike, that looks like a one piece cover to me...am I wrong? I had a Cloyes 2 piece and loved it...never leaked...but of course the cover set me back a little over $100, so it shouldn't have.
-Jeff
bigblock73 is offline   Reply With Quote
Old 11-17-2003, 10:21 AM   #8
Mike76251
Jeff,
You might be right..............it has been too long since I did it!
I did go through 3 different covers before I found one that works right.
I do know what I said above happened........that two-piece leaked badly.
I got the Mr. Gasket two-piece off eBay for $15 or so and it looked straight and all but it still leaked.
Old 11-17-2003, 10:52 AM   #9
TwinTurbo
TwinTurbo's Avatar
Those cheap 2 pc ones will most likely leak. the sturdy aluminium ones are much better. I have milodon gear drives (one is erson brand but it''s exactly the same as the milodon one, just labelled differently) on my 2 corvette engines and I love them, combined with spring loaded roller lifter it just takes backing off the rockers and removing the cover to swap a cam.
TwinTurbo is offline   Reply With Quote
Old 11-17-2003, 11:44 AM   #10
crackajacka
Stylin
crackajacka's Avatar
i really didnt think it was all that big of a deal when i tore down my motor and removed the one piece and nothing fell out. you should go with a high quality 1piece
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 11-17-2003, 08:09 PM   #11
stan79chevy
stan79chevy's Avatar
how fast are you guys going throgh cams?
taking the oil pan off isnt really that hard and if your cam is out anyway i wouldnt think you want to reuse the oil. what are the advantages of a 2 piece
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 11-17-2003, 08:30 PM   #12
TwinTurbo
TwinTurbo's Avatar
Stan, from that point of view you're right, however some people (like me) change cams not because the old one got chewed up but to test something new, jsut to make an improvement (cam tech isn''t standing still, the lobes get increasingly more aggressive)
Old 11-17-2003, 08:34 PM   #13
swervin ervin
You get what you pay for
swervin ervin's Avatar
The advantage is not having to remove the pan or timing cover when/if you do change cams.
Another advantage is the cool factor.
Some things we all do is not of any real benefit, but dayum, it sure is cool to say we have it or have done it.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 11-17-2003, 08:39 PM   #14
boataddict26
Perfect explaination swervin!!
Old 11-17-2003, 08:39 PM   #15
crackajacka
Stylin
yea that is true, but when i pulled the timing cover on my 305 thats sitting in the shop floor i could put it back on without any trouble. i guess it wouldnt seat right or anything huh
Old 11-17-2003, 09:14 PM   #16
1FaastC10
1FaastC10's Avatar
i've noticed mention of a Mr Gasket timing covers, and their poor quality. when someone posts about one, the have already discovered their problem, they just dont realize it. Mr Gasket used to be decent stuff, but in my experiences more recently Mr Gasket ranks right up there with ProForm. its JUNK.
Old 11-18-2003, 10:21 AM   #17
Mike76251
Junk..........yeah
I went in for some flexplate bolts the other day @ NAPA and ask for ARP bolts.
The guy behind the counter said "why don't you use Mr Gasket bolts?"
I tried to be nice and just said "no thanks"
Maybe I should take out my ARP rod bolts and replace them with Mr Gasket?!?
Old 11-18-2003, 01:10 PM   #18
1FaastC10
1FaastC10's Avatar
Originally posted by Mike76251
Junk..........yeah
hey, that might be a great idea for i high hp engine. it'd definitely keep you from tears tarnnys up. puttin out too much power? just snap the flexplate bolts off, never even have to thinks twice about hurting the trans.
