Old 09-10-2018, 08:42 PM   #1
Bryan H
Bryan H's Avatar
Do I need a high hump for a 4L60E?
Hey folks. I haven’t been on here in a while with a question but finally getting back to my project. Was wondering do I need a high hump trans tunnel to run a 4L80E and a 5.3 or will a low hump work just fine? I was thinking the trans is bulkier on the driveshaft end of the trans. Thanks
1980 Malibu Classic 2 dr coupe
1964 Impala SS 4 speed
1968 GMC (major project) grandpa bought new
1969 Chevrolet C-10 Shortbed Fleetside
2013 Silverado LT
Bryan H is offline   Reply With Quote
Old 09-10-2018, 09:16 PM   #2
darrellyates
Re: Do I need a high hump for a 4L60E?
I'm running a 6.2 with a 4L60E and the low hump works fine. It's tight on the top, just a couple of inches, but it fits OK. No issue with the column shifter hooking up either, I used a Lokar rod kit. Had to bend it a little, but it works excellent.
On a previous build, I had a 5.3 with a 4L60E there as well, no issues with either one.
Hope this helps, and good luck!!
darrellyates is offline   Reply With Quote
Old 09-10-2018, 09:21 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
Ditto on the no need for the high hump...
Have mine installed now and no worries with clearance...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2025 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 09-10-2018, 09:44 PM   #4
Bryan H
Bryan H's Avatar
Thanks y’all.
2013 Silverado LT
Old 09-11-2018, 10:58 AM   #5
Bentbolt
low hump and 4l60e combo work with truck pan oil pan on a slammed truck? im about to fit the engine but heard I might need a f body oil pan.
1965 C10 long box laid out on bags
instgram 65see_x
.……………………….. ____
..………________//__l \_____
,,,,,,,/__(O)___//___/__(O)_/
Bentbolt is offline   Reply With Quote
Old 09-11-2018, 11:01 AM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Anything lower than 4” in the front will need the fbody pan
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-11-2018, 11:02 AM   #7
Bentbolt
thanks I wasn't sure if I could raise the whole engine and tranny up or not.
instgram 65see_x
.……………………….. ____
Old 09-11-2018, 04:59 PM   #8
1957 Chief
Retired USAF
CTS-V pan works pretty good.
Bubba
1957 Chief is offline   Reply With Quote
