What to do
Last night was adjusting the valves and guess what #2 exhaust valve does not open as much like the rest. Flat lobe. Engine is a sbc 350 I replaced rings bearings gaskets I did a budget rebuild. To do it right I got to pull the engine out and do a complete tear down and cleaning. I also have a little 307 that came in the truck for some reason I want to build it the only drawback on the 307 it has a piston ridge which will need new over size piston more $$$. what should I do 307 or the 350. I would like a efficient v8 maybe 300hp. Both would get a set off heads from jegs or summit
![]() Join Date: Dec 2009
Re: What to do
350
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
Re: What to do
Any tricks on removing and installing the engine, truck has a sm465 transmission. I've done a buch of automatic transmission but never a manual
Re: What to do
I would definitely rebuild the 350 over the 307. 300 hp with a set of aftermarket heads will be easy with the 350. Check out some vortec heads. They’ll require a different intake, but they flow really well. Do your research first though, the factory vortec heads require some machining to take lift over .460. The aftermarket ones may not. A small cam and vortec heads would make more than the 300 you’re after. As far as R&R tips, I like to pull the engine and trans as a unit. To me it’s easier.
![]() Join Date: Aug 2004
Re: What to do
If you can find one for a good deal, run a later vortec 350 block (880 casting). No more worries about a flat cam, and you get the good heads with it. In stock configuration it will move your truck along nicely.
You're looking at a rebuild anyway, this is a better foundation.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Moderator
![]() Join Date: Jun 2017
Re: What to do
Totally agree on getting yourself a used Vortec style 350 as a starter for the build....
Better heads Roller style cam (no more flat lobes) One piece rear main oil seal As mentioned, you will need a different intake but the Vortec style 350 is the best choice by far... Have fun ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2025 Chevy Equinox ![]() ![]()
Re: What to do
Do NOT try to pull the engine and trans out in one swipe. You'll have to remove the trans first, then pull the engine. The transmission is about 1" too tall to fit between the bottom of the cab and the transmission crossmember. Been there, done that, got the greasy T-shirt to prove it.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
Re: What to do
Can i leave the transmission in place?
| Bookmarks |
