Old 09-29-2018, 11:58 PM   #1
Taylor21293
Taylor21293's Avatar
1971 C10 Stock Gauge Size?
Looking for gauges that will slide right into a stock bezel, does anyone know the sizes of the holes (or gauge size) for a stock C10 bezel?
Eatin' up Dodges and ****tin' out Fords
Taylor21293 is offline   Reply With Quote
Old 09-30-2018, 08:50 AM   #2
Mike C
Mike C's Avatar
Re: 1971 C10 Stock Gauge Size?
Aftermarket 2 1/16” gauges will go in from the front on the stock gauge panel for the 4 lower holes. An aftermarket 3 3/8” tach will fit in the center hole. I did these mods on my Jimmy. I kept the OEM speedo and fuel gauge.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-30-2018, 09:34 AM   #3
Taylor21293
Do you know what size the OEM speedo and fuel gauge holes or gauges are? I can’t seem to find a straight answer, and I unfortunately don’t have an OEM speedo or fuel gauge
Old 09-30-2018, 11:04 PM   #4
72 k15
72 k15's Avatar
I could go measure mine for you if he doesn’t respond.
72 k15 is offline   Reply With Quote
Old 10-01-2018, 03:27 PM   #5
68 P.O.S.
5 inch
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
