Old 10-24-2018, 11:08 PM   #1
Llay R. Rac
Llay R. Rac's Avatar
what this hole for?
I took the rear bumper off my '65 suburban to paint it and install a bumper to body seal i am making.
I found these holes on both sides, plugged with a gray/silver plastic plug, the same as those that plug the holes in the side support where hinges would be if my sub with end gates was a barn door style.
I have owned this truck since 1969, i dont remember drilling these holes, but i also havent seen or heard anything about them either on pickups or suburbans. thats the plug sitting on the ledge above the hole.
so i assume they are factory, does anyone know?Name:  DSCF4086c.jpg
1965 Suburban, 2 wd.,292, 4-speed.
proudly owned and operated since Valentines day 1969.
Llay R. Rac is offline   Reply With Quote
Old 10-24-2018, 11:50 PM   #2
Captainfab
60-66 Nut
Re: what this hole for?
Could it be an access hole to be able to clean out the boxed in rear quarters similar to what the rocker panels have?
Old 10-24-2018, 11:52 PM   #3
franken
Not likely in AZ but rustproofing?
franken is offline   Reply With Quote
Old 10-24-2018, 11:56 PM   #4
Getter-Done
Getter-Done's Avatar
It could be an aligning hole for assembly in the factory.
The early bird gets the worm,
85 Chevy K-20
