11-11-2018, 05:04 PM | #1 |
laying low
truck plans over the winter?
Now that colder weather is coming some of you will most likely take your truck off the street for the winter. What do you plan to do to your truck while it's down?
Yesterday I put up my lawn cutting equipment and made more room in my small shop. I plan to finally blow my stepside bed apart and begin the repairs on it.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
11-11-2018, 05:19 PM | #2 |
Re: truck plans over the winter?
I am going to start a complete restore on my 72. Down to frame and start over.
11-11-2018, 05:24 PM | #3 |
Assemble a new bed kit and finish my extended cab project
11-11-2018, 05:36 PM | #4 |
Put everything back on that is missing from this pic, and also the new bed
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
11-11-2018, 05:38 PM | #5 |
laying low
That's going to be nice.
11-11-2018, 06:03 PM | #6 |
laying low
flip'd
11-11-2018, 06:38 PM | #7 |
laying low
When I put my step side bed behind the shop it had no rust and a solid floor. That was 20 years ago. I had no intention it would be this long. The good thing is now days there are plenty of new parts available if needed.
11-11-2018, 07:23 PM | #8 |
Looks like a nice project stovebolt
11-11-2018, 07:40 PM | #9 |
Thanks for the flip Boog. I even edited that pic before I posted it.
11-11-2018, 07:41 PM | #10 |
Thank you, your extended cab looks sweet too
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear Last edited by 70STOVEBOLT; 11-12-2018 at 10:25 AM. |
11-11-2018, 11:00 PM | #11 |
Simple one, rear brakes because I don’t think they work.
Regards Steve |
11-11-2018, 11:18 PM | #12 |
I am going to remove the bed wood and sand and refinish.
Possibly TMI seat and vintage air.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
11-11-2018, 11:42 PM | #13 |
Active Member
I've got an appointment for new exhaust on the 19th of this month. It's been at or below 30 degrees lately and I've got no heat in my C20. I'm hoping to investigate the blower motor and replace the slide switches and faceplate in the dash. I don't have AC, so no worries there. Any tips on finding a solution to my lack of heat would be very helpful. Thanks!
The Dude abides. |
11-12-2018, 12:01 AM | #14 |
I have been working on all the mechanical bits while driving my 68 fleetside this summer. Including wiring, factory A/C rebuild, steering gearbox and complete cooling system overhaul. When I bed her down for the winter hibernation she will get her front end rebuilt with disc brakes, re-geared with 3:73 gears and the new 700r4 installed that has been waiting patiently on my shop floor. Hopefully this time next year she will be getting ready for paint.
11-12-2018, 07:23 AM | #15 |
Old member
I plan on driving the 71 this winter some when the weather permits.
The ramp truck is getting tilt steering and some floor work and maybe some more stuff done. Going to take the drive shafts out and replace the carrier's along with all new unversals.
11-12-2018, 09:40 AM | #16 |
BlahBlahBlah
My only plan is to keep getting rid of all my trucks. When there is one left, its the one that stays. Too bad winter is a sucky time to try and get rid of stuff haha.
11-12-2018, 09:57 AM | #17 |
Switching to EFI. Possibly swapping in a 6 speed. Maybe get new wheels, but unlikely. LOL
11-12-2018, 07:09 PM | #18 |
Going to be doing a correct 2/4 drop, brake upgrade, new brake lines, new booster and MC as well as a rearend change on my 69.
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. |
11-12-2018, 09:00 PM | #19 |
new frame!
Posted via Mobile Device |
11-12-2018, 09:07 PM | #20 |
Moderator
Intend to finish the tear down of my 67 Long Box and do the frame from front to back...swap in full disk front cross member from a donor 78...and setup 4 / 6 drop....
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
11-12-2018, 09:25 PM | #21 |
Plan on taking out the diamond tread plate and replacing the wood in the bed and do some interior work on the 1967 C10 stepside.
11-12-2018, 10:44 PM | #22 |
install brake lines, exhaust fuel cell & lines install cab distributor clearence and trans c member location for clearence and drive shaft fitment ....i get that all done ill starton finishing up all engine brackets PS alt plug wires etc. need some help flipping the pic!
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
11-12-2018, 10:58 PM | #23 |
Just get it back home from paint and body and put it back together. Should have it within a couple of weeks - I hope. It has been a year, but the guy does super nice work. He did both my GTO's previously. He does the body work and primer in his shop ( and the inside) and will take it to his workplace to shoot the outside in the paint booth. Here is a photo of my 65 that he did the body and paint. Gave the car to my son in NC last April
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 Last edited by rsavage; 11-12-2018 at 11:03 PM. |
11-13-2018, 12:17 AM | #24 |
laying low
flipd zic
11-13-2018, 12:52 AM | #25 |
