Old 12-01-2018, 07:22 AM   #1
Pdub1972
Repair panels
Im replacing rusty panels, and was wondering if after i got them replaced if i can put expanding foam or something comparitive to it inside the posts and areas that collect dirt to avoid dirt buildup again?
Pdub1972 is offline   Reply With Quote
Old 12-01-2018, 10:05 AM   #2
Andyking1203
Re: Repair panels
I wouldn't do foam!!!! But maybe make and weld in small patch panels to avoid this, I think would be a better option...
Andyking1203 is offline   Reply With Quote
Old 12-01-2018, 09:55 PM   #3
rjs53
Re: Repair panels
The foam ever gets moisture in it, the rust take over
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 12-03-2018, 07:44 AM   #4
Metaldoc
Metaldoc's Avatar
Re: Repair panels
Put in drain cut outs
Do it, Do it right, Do it right the first time
Metaldoc is offline   Reply With Quote
Old 01-07-2019, 04:14 AM   #5
Southpaw69
Re: Repair panels
When I got into mine I found spray foam in the passenger side kick panel, rocker and it even made it into the cab support. They used it to have something for the bondo to stick to. It amplified the rot. Once you remove and replace the bad metal you can hit it with a coating that will seal it. I used the eastwood rust encapsulator inside the rocker and anywhere that I could get to to prep it. In tight spots like the 'a' pillar and roof area I used the internal frame coating with the 2 foot extension tube as well as I could. Drain holes are always a good idea too, as Metaldoc said.
Southpaw69 is offline   Reply With Quote
